Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL 40 HD
After a storm yesterday morning, the TV just rotates through a series of screen colors, red, green, blue, then a striped screen red, green blue , and white, I have cycled power for 15 seconds a few times, and I get sound, I can change between the video inputs but only by sound, because I can't get anything on the screen except for the colors? lightning may have surged it, I;m not sure
  • sonycoll Sep 09, 2008
    thanks, thatd kinda what I figured, I did try unplugging it for 15 seconds then replugging it, with no change.
  • Anonymous Mar 23, 2014
    the picture looks dim but more colors like red and blue. but other functions are working well like sound
  • 51 Answers
It's in a service test mode. have you unplugged the tv? that should reset the tv..if you still have problems after ..it will need repair.
Posted on Sep 09, 2008
  • Micah
    Micah Sep 09, 2008
    well, it is probably a power surge problem...
How do i set convergence of red,green ,blue through service mode
Most common cause for this on the Sony KDL 40EX520 is that the connections to the screen across the top edge of the panel become loose causing blurred picture, mis-aligned colors etc. The Fix requires dis-assembly (Removal of the entire case) and re-seating/resecuring the connection across the top of the LCD Panel.
There is a pretty detailed video of the process (less the disassembly) here: https://www.youtube.com/watch?v=80PfZXFGDvQ
Jan 10, 2015 | Sony KDL40EX520 Bravia KDL-40EX520 40 Inch...
My 40 inch S400A Series Full HD BRAVIA LCD TV does not turn on. When i plug it in, the green light (next to the Red power light) blinks. If i try to power on via remote, the red power light turns on and...
this again sounds like the power supply,.if you hear a click when you push the power button, this means your main board is reading good so replace the power supply,.
Apr 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Our sony bravia has no blue color
If you are using the component video hookup which is 3 wire. green, Blue ,Red and red and white audio. be sure that all 3 of the video wires are pushed in all the way. check both ends. Replace cable. if all 3 are not connected then color will be be goofy. Let me know if this doe not help.
Aug 30, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a 40inch Sony Bravia and all of a sudden I have 4 pin stripe lines on the left side of the screen 2 red 2 blue
This tv have a dead board call the T-CON decoders board.This board sit right at the bottom at the middle of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Oct 21, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony bravia kdl40S504 has green ghosts - cannot
I do not think that cause by power surge, and it is on manufactory warranty, you better to call Sony.
Jun 26, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA KDL-40S2000 color problem
you might had problem with the video switcher board. The A board.
Feb 28, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Screen is green when trying to play a DVD
I think DVD player is hooked with TV via component video input.
Check component video connections and make sure each color wire connect in same correspondence color in both units, TV and DVD Player.
Red to red, green to green and blue to blue.
Dec 18, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
SONY BRAVIA KDL-40S2010 40"
Mine isnt even 1 year old and same problem. was fine last night, woke this morning, turned it on and there they are green and purple
Apr 08, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Connecting old DVD player to LCD
Just respect the colors. Green output from the dvd to green input tv, Red output from the dvd to red input tv and the same with blue. All 3 cables (green , red, blue) are for the picture, so you got to plug another 2 for the sound.
Dec 25, 2007 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
Sony bravia lcd tv-
If you are using a HD cable box or satelite with component outputs, be sure that all 3 cables ( green, red, and blue ) are making good connection.A loss of red or blue will cause color shift. Usually,if the tv menu comes up as the correct color but the picture dose'nt, it is most likely a signal problem.
Jul 01, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
723 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
