Recently installed Virgin V box and trying to adjust volume on the remote for a JVC Tv Model no.LT-26DS75SJ.All the codes that Virgin suggest don't work,can anybody help please.
    Master:
  • 505 Answers
What the model of the v box
Posted on Sep 10, 2008
  • Most Defaults code can be 1234 or 0000 but i will need the model of the Virgin V Box so i can assist you
The remote control on my JVC model number LT.32DS6BJ will only work to adjust volume and nothing else please help
this can be from dirty keyboard in remote, can clean with isopropyl alcohol. just wipe down keyboard and keypad, let dry and test. Or could be a bad infrared reciever board in tv. Meder's tv service.....good success and God bless
Aug 09, 2013 | JVC Televison & Video
Dish Satellite recently installed in my home supporting several tvs. MY JVC TV model LT32E478, designated as TV1, does not recognize any channels during program scanning. As a result, the timer on/off...
Hi mfaille
I`m going to help you with your setup but first;
Which connection are you using from the sat receiver to the tv?
Coax / standard rg6 cable?
Did you try to manually add(in the menu/tuner setup/find channel/add) the channel you need ?
May 17, 2010 | JVC LT-37E478 TV
JVC LT-42P300 Remote Codes
What remote? It depends on the remote. Different remotes use different codes. They all have a code search function that you can use to find the code.
Sep 19, 2009 | JVC LT-42X579 42 in. LCD TV
Need codes where can i find them
To set up the volume control on your virgin remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
TV Codes
Akai 0236, 0544, 0630
Alba 0037, 0065, 0246
Amstrad 0205, 0440, 0065
Bush 0246, 0263, 0377
Decca 0064, 0100, 0544
Ferguson 0101, 0363, 0221
Fidelity 0244, 0221, 0460
Finlandia 0374, 0387, 0236
Goodmans 0065, 0064, 0100
Granada 0379, 0387, 0391
Grundig 0563, 0582, 0515
Hinari 0037, 0064, 0065
Hitachi 0253, 0384, 0377
JVC 0681, 0081, 0122
Matsui 0263, 0205, 0037
Mitsubishi 0136, 0382, 0064
NEI 0065, 0365, 0459
Nokia 0508, 0501, 0576
Panasonic 0678, 0254, 0278
Philips 0584, 0065, 0040
Saisho 0039, 0205, 0263
Samsung 0065, 0584, 0037
Sanyo 0236, 0073, 0100
Sharp 0121, 0064, 0065
Sony 0533, 0038, 0039
Tatung 0065, 0100, 0544
Thomson 0363, 0653, 0137
Toshiba 0536, 0063, 0271
If I have not listed your make of TV in the table above,
1. Press to go to the Home Screen.
2. Choose Telewest Services.
3. Choose Technical Assistance.
4. Choose TV Control Codes.
5. A full list of TV brand codes will appear.
If the volume control is still not working after trying all the codes for your TV model, or your TV model is not listed, then your TV is not compatible with our remote control and you will need to use your TV remote to control the volume as normal.
You can also use your TV remote control to adjust the volume in the normal way. Good Luck
Jul 27, 2009 | Televison & Video
My remote wont change channels
I need to use the cable remote to change the channel and the TV remote to change volume.
That is because your TV is looking at the output of the cable box (probably on channel 3 or 4) so the TV has to be statically tuned to see the cable box's output.
On the second question; I, and perhaps others, can't answer this without spending a lot of time to download manuals for both systems while you have them (presumably, since they are new) on hand. You didn't include the TV's model number anyhow so even that wouldn't be adequate.
The home theatre may have a receiver but what does it receive? Unless it also has channel capabilities that correspond to cable channels, it can't. The typical routing should be from the cable box to the TV S-video input and the sound can be routed separately from the cable box to either/or both, the home theatre's and also the TV's audio inputs.
When I am installing new stuff, I make a sketch of the routing I want (or have) to use. To me, this is less confusing than the supplied instructions.
Feb 01, 2009 | JVC LT-42X579 42 in. LCD TV
Orion tv need codes for remote control.
I need help with remote control rca r5464 for orion tv
Dec 19, 2008 | Orion1934 19" TV
LG 37LC2D TV Virgin Cable remote codes
I had the same problem with a LG42lf2500 I tried all codes that Virgin had listed none worked. I then started to program volume control stating at code 0001. 0007 worked for my LG TV LG42lf2500
Jan 08, 2008 | LG 37LC2D Television
Virgin media tv remote control
what you have to do is ring virgin and ask then to send the code.
this code is done stight to your set top box
Nov 07, 2007 | Televison & Video
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
