Question about Intel D845GVSR Motherboard
Acpi bios P4 Acpi
  • Anonymous Sep 10, 2008
    suleman 9945021607
Sir problems are acpi bios
and windows service pack 3 cd instal the computer ntfs.dll currupted see here
Posted on Sep 10, 2008
    President:
  • 2,351 Answers
Hi suleman_indi, I'm guessing you have a question about the D845GVSR motherboard. If your question refers to the bios setting for ACPI. Disable it until windows has been updated to SP2. Enter your bios & enable the ACPI. Should be fine once windows has been updated. Click on this link to load Intel's site for the Intel D845GVSR motherboard.
http://downloadcenter.intel.com/Product_Search.aspx?Prod_nm=+D845GVSR&lang=eng&MissingSearchTxt=Please+enter+a+valid+product+name%2C+filename+or+product+ID+%23.&x=21&y=5
If you find you need more information, feel free to update your question.
Mike
Posted on Sep 09, 2008
2 Suggested Answers
The Machine
  • 788 Answers
SOURCE: acpi complaint - reg
Reset you BIOS to it's default. Hit Del/F1/F2/F10 or whatever key the machine prompts you when it first boots to get into system setup. Then pole around to find a restore to defaults option.
Or you may in fact have to upgrade the BIOS, what kind of system or motherboard to you have?
Posted on Jan 17, 2008
Why ACPI not supported by upgrade to windows 7
acpi is supporrted by win 7 just make sure ist on in the bios and download acpi driver from the motherboard factory
Microsoft ACPI Driver Windows 7 Service batcmd com
Sep 05, 2014 | Computers & Internet
WHO MAKES BIOS FOR TECRA?
ACPI Flash BIOS version 3.20 for Tecra A8 (PTA82) Posted Date: 2016-09-19 ' Version: 3.20 ' Size: 3.82M ACPI Flash BIOS version 3.30 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 3.30 ' Size: 3.82M ACPI Flash BIOS version 1.40 for Tecra A8 (PTA82U) Posted Date: 2016-08-24 ' Version: 1.40 ' Size: 3.54M ACPI Flash BIOS version 1.60 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.60 ' Size: 3.52M ACPI Flash BIOS version 1.50 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.50 ' Size: 3.54M ACPI Flash BIOS version 1.30 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.30 ' Size: 3.54M
Apr 02, 2014 | Toshiba Tecra A8-EZ8311 Notebook
Blue screen of death says acpi bios noncompliance. Help!!
Did you change something in the bios? Enter the BIOS and check the Power Management or just Power settings and disable ACPI. This should solve the problem.Windows would again find new hardware and then should work normally.If ACPI not found under power it could also be under Advanced tab. Did you install any new hardware?.The hardware might be non ACPI compliant hence the error.
Jan 21, 2011 | HP Compaq Presario SR1303wm PC Desktop
ACPI is not a compliant
Enter you bios & disable ACPI. Restart the system. Than update your windows. There should be an update for ACPI through Microsoft update service. Once installed restart your system & enter into your bios. Now enable ACPI. Save & exit the bios.
If this does not help you can try the work around found on Microsoft's web site. See the link provided;
http://support.microsoft.com/kb/314830
Cheers
Mike
Jun 01, 2009 | MSI Computers & Internet
Dell Inspiron 1100 Bios and ACPI
Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
RESOLUTION
Manually install the Standard PC hardware abstraction layer (HAL):
1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant
Mar 16, 2009 | Dell Inspiron 1100 Notebook
How to install Windows Vista On IBM NetVista 830331G
newer os like xp and vista have many new power management feautures like acpi-advanced configuration power interface.. when booting your pc press DEL or f2 to enter bios and check if your bios supports this feature.. i have not used ibm pcs but still check with this..
Feb 10, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
I have ACPI problem. said when i was trying to install os on my system and it said "the bios in this system is not fully ACPI compliant" pls what can i do
For that particular software you are using,,the ACPI thinks your Bios needs updating.
You can re flash the Bios to a newer version if one is available, and if one isn't available,,then i would suggest turning off the ACPI functions in your system Bios.
ACPI controls the power saving features of your machine via the software, also the power saving features on any legacy devices attached to your system.
Jan 19, 2009 | Computers & Internet
The BIOS in the system is not fully ACPI compliant. I want to updated BIOS. How can I do?
Hi meangmoeurn, what makes you think your bios is not ACPI complaint?
Enter your bios & disable ACPI. The reason for this is windows must be fully updated. One windows has been fully updated you can turn on ACPI. Its a software issue.
Read through this Microsoft link;
http://support.microsoft.com/kb/314088
Update for ACPI, (Windows update);
http://www.microsoft.com/downloads/details.aspx?familyid=B0FF829D-C427-4F40-BC56-F481837EFFBE&displaylang=en
The above update should be included with other updates. This is why I suggested the above.
If you still feel you need to update your bios,
(Flash Utility software). I'll need the motherboard model number & manufacture's name.
Good luck meangmoeurn!
Feel free to correct me on this issue.
Thank you for using fixya.
Mike
Jan 11, 2009 | Computers & Internet
I need to disable tha acpi on an acer travelmate 529tx but i don't know how to do it. i am trying to install xp after a failure. i get bsod and says to press f7 when i install storage drivers but i need a...
I have seen on many forums that ACPI makes a lot of troubles to a lot of users under Windows. I will try to explain several things about ACPI and I hope that you will be able to solve your problems after you read this article. I cover only most encountered issues, but always there is a choice even if it's called ACPI disable.:)
The computer ACPI support is detected in the setup stage, but there are less frequent cases when ACPI is not detected and the Standard PC HAL is installed. If you want to force the installation of the ACPI HAL:
1. At the blue screen of the Windows XP setup when it prompts you to press F6 for additional mass storage devices press F5 and you will have a list of options.
2. Choose the proper HAL for your machine remembering that there are also different HALs for multiprocessor machines.
3. Complete the setup, go to Setup / Control Panel / System / Hardware / Device Manager / Computer. If you have listed the Advanced configuration and Power Management (ACPI) the process was completed successfully.
Warning: You can do the same thing if you don't want to install ACPI and your BIOS doesn't support ACPI disable setting. Just choose the Standard Computer HAL from the list of options.
Another method to disable ACPI is:
  • wait for the text-phase of XP setup to complete
  • before XP Setup Wizard to load, boot into DOS and change ACPIEnable = 0 from ACPIEnable = 1 in file c:\txtsetup.sif
The reason why ACPI is not installed on a computer with known ACPI compatibility may be a Microsoft known subtle incompatibility which can lead to hardware instability. In the installation step Windows XP checks the BIOS compatibility with ACPI and the BIOS presence on a known bad list. If the BIOS is there ACPI is not installed. Of course than errors can occur so you can force the ACPI installation (not recommended).
Try disabling it in the BIOS first, this can not be done on a computer with the operating system already installed as it will cause the machine to stop. MUST be done when you initially install the OPERATING SYSTEM.
Regards.
Nov 16, 2008 | Acer Computers & Internet
System reboots when acpi turned off
Hi martinkp, what you need is the update from windows. Leave you're acpi enabled withing the bios. Check windows update. Windows will update (windows software for the acpi). Rule of thumb concerning windows update. Check the dates of the updates & install in order, oldest to newest. This should fix you're system from shutting down. There will be no reason to turn off acpi after updating.
Mike
Apr 06, 2008 | MSI K9VGM-V Motherboard
Intel D845GVSR Motherboard Logo
173 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
