My security password (key) doesn`t work cause there is only room for 16 digits and I have 20
    President:
  • 2,961 Answers
That means that the security level is wpa-psk on the router, but your pc only supports wep, you need to change to wep security in the router settings for this 16 digit pass code
Posted on Sep 09, 2008
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
Forgot my flip camera security code
  • 1 Enter the number you think is your 4-digit unlock code. Do it once slowly, so you don't waste the number of tries you're allowed before the cam completely locks. If you never set a code, try 1234. The factory sets this as the default. If that fails, try the last four digits of your home phone number. That's the default of some network providers. If all these fail, go to Step 2.
  • 2 Click the menu key, which has horizontal lines on it. It sits between the left and right soft keys and above the round 5-way navigation keys. You should now see the unlock code bypass screen. Enter your 6-digit security code. Select "OK." If this doesn't work or you don't remember your security code, go to Step 3.
  • 3
  • Try 000000 as the factory default setting for the security code. If that doesn't work, go to Step 4.
  • 4 Call your network's customer service center. Locked ones usually let you call both customer service and 911. However, calling on a separate phone will make entering the code they give you easier to enter and test while they're still on the phone with you.
  • HID KITS.
    Jun 01, 2012 | Pure Digital Flip Video Camcorder
    How can i reset the bios password in my toshiba satellite 4010 CDS? i already tried removing the cymos but it didnt work! pliz help!!!
    Removing the clock battery doesn't do anything to the CMOS passwords. You can go buy a parallel port password key (I've seen them sell for $20, $30 bucks on eBay), or you can get yourself an old, parallel printer cable, and make a parallel port password key yourself (I did, took me about an hour's worth of time). If you decide to DIY, you can wire a parallel cable according to this:
    Connect these pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15, 18-25
    Sep 10, 2011 | Computers & Internet
    I need a password. Tried this password - 3155304945 - that was on unit but would not work
    To reset password with software version 4.25.X or higher:
    1. Click I forgot the password to receive a hint to the password. 3.7_reset_pw_001.jpg
    2. Click I still can't remember the password if the hint does not help. 3.7_reset_pw_002.jpg
      The Reset System Password page opens, asking for the "System Key." This is the 10-digit WEP key from the bottom of the HomePortal. (The printed number stays unchanged even if you have changed the wireless security settings on the unit.)
    3. Enter the 10-digit WEP key, select a new password, enter it again to confirm the password, and give yourself a new hint to the password.
    4. Click Submit and your password is updated.
    Temporary Passwords:
    A customer may call in stating that their 2Wire is asking for a temporary password. You will need to use CMS to reset their Gateway password.
    1. Open CMS
    2. The customer will read you the 20 digit code they see on their screen
    3. You will generate a temporary password that is only good for 15 minutes.
    4. The customer will enter the temporary password then create a new password.
    After 15 minutes both the 20 digit code and the temporary password expire. If the password process has not been complete in this time frame the page will need to be refreshed for a new 20 digit code.
    Now you can use the new password to enter the HomePortal protected areas and the Management and Diagnostic Console.
    Nov 15, 2010 | 2wire (1000-400108-001) Router
    Trying to find wep key to connect dsi with netgear wgr614 v9
    You can find the wireless security password by accessing the router'sadmin page http://192.168.0.1 (username is admin and password is password) then go to the wireless security tab.There you can find the password or WEP key (10-digit code). If you can't login to the router'sadmin page, you can reset the router by pressing the reset button atthe back of it for 20 seconds then power cycle the router by turning itoff for 10 seconds.
    Apr 15, 2009 | NetGear WGR614 Wireless Router
    I can't remember by netgear wp824 password - or WEP key - would it be a number?
    You can find the wireless security password by accessing the router's admin page http://192.168.1.1 (username is admin and password is password) then go to the wireless security tab. There you can find the password or WEP key (10-digit code). If you can't login to the router's admin page, you can reset the router by pressing the reset button at the back of it for 20 seconds then power cycle the router by turning it off for 10 seconds.
    Apr 15, 2009 | NetGear : WPN824 Wireless 802.11g Router...
    Security
    No Problem I"ll set it up for you
    1. Follow these steps but only from base computer (any comp which is physicall connected to the router )
    2. Open router set up page by typing in 192.168.2.1 on your brouser tab only the numbers please.
    3. If that dosent work type http://192.168.2.1 on the run window.
    4. Once the setup page is up on the left hand side under wireless you"ll find Security the second tab .
    5. Click on that
    6. Selet 64 bit wep or wpa .
    7. According to my experience and believe me i have sorted hundreds of such my essentials 64 bit wep is best .
    8. If you select 64 bit wep enter a 10 digit no in key one. ONLY KEY ONE . ( that will be your security key ). Apply changes . The router will Reboot .
    OR
    9. Select wpa ( no server ) youll have to enter a password .Apply changes . Router will reboot .
    Note: IN EITHER CASE DONT PUT ANYTHING IN GENERATE PASSWORD. PLEASE . MANUALLY INPUT PASSWORD .
    10. Your security is set up
    11. Now change channell to 11 or 6 for best signal reception.
    12. Youll find that under wireless (channell and ssid)
    13 . Click ok . Allow router to reboot or save changes whatever .
    14. Disconnect on your wireless .
    15. Reconnect on wireless . it will ask you for a password .
    16 . Depending on wep or wpa you have selected type 10 digit no or password .
    17 . Your Network nis now secure
    Do let me know and if it is resolved please do rate me
    Feb 15, 2009 | Belkin My Essential (ME1004-R) Wireless...
    My son forgot his security code for his motorola v360. pls help!!
    I think this will help....
    codes & passwords
    Your phone’s 4-digit unlock code is originally set to 1234.
    The 6-digit security code is originally set to 000000. If your
    service provider didn’t change these codes, you should
    change them:
    Find it: Press M > Settings > Security > New Passwords
    You can also change your SIM PIN or call barring passwords.
    If you forget your unlock code: At the Enter Unlock Code prompt,
    try entering 1234 or the last four digits of your phone
    number. If that doesn’t work, press M and enter your 6-digit
    security code instead.
    If you forget other codes: If you forget your security code,
    SIM PIN code, PIN2 code, or call barring password, contact
    Jan 27, 2009 | Motorola Mobility V360 Cellular Phone
    Too long CD Key
    because you didn't say it was a game, you mentioned security, games don't have security as you mentioned in your first post, although they have product keys.
    That's why i posted a router security solution.
    we cannot answer correctly if you don't post the full details of your problem.
    Whoever give you the keycode is who you need to quiery it with.
    Sep 10, 2008 | Computers & Internet
    Passwords
    If you don't know the WEP key, then the security is working (ironic, isn't it?)
    If you want the Wii online, you will need to log into the router's interface and disable encryption entirely or (depending on the router) simply change the security key.
    Bear in mind that if you change the key, all the other wireless devices will no longer work until you update them with the proper key.
    Hope this helps - be sure to rate :)
    Sep 08, 2008 | Belkin (F5D7231UK4) Wireless Router
    Computers & Internet Logo
    29 people viewed this question
    David Payne
    David Payne
