Question about RCA P61927 61" Rear Projection Television
Scratched tv screen
I have a 61inch Hdtv my 2yr old niece scratched the screen with the a pair of scissors i wanted to know if there was a way to get the scratches off the screen or how much it would it cost to repair it or would i need to replace the screen if so how much would that be
  • 3 more comments
  • Anonymous Mar 28, 2008
    I HAVE SCRATCHED SCREEN HITACHI MODEL 50VX15K REAR PROJECTION OCT.93 SERIAL#V3J004007 CANNOT FIND REPLACEMENT SCREEN COVER CAN ANY ONE LOCATE ONE FOR THIS TV,FOR ME?
    My two year old son did the same thing only with a screwdriver. in parts its is pretty deep but mostly just scratches.
  • Anonymous Jul 01, 2008
    My dog was chasing a fly and put several large scratches on my TV screen (54" samsung with no screen protector). How can it be fixed?
  • realtrose Nov 03, 2008
    in addition to your two year olds and dog, my 72 year old mother made a 12" deep scratch in my 48" samsung screen playing Wii tennis. She has offered to replace the screen is that possible?
  • markybie227 Mar 17, 2009
    My widescreen tv has a few scratches on the glass screen, can i repair it without replacing it
    Scholar:
  • 76 Answers
I replaced the screen on my 62 inch projection TV for about $50 and the the picture quality is good! Have a sheet of plexiglass cut to the EXACT size needed. BEFORE installation it MUST be frosted on both sides by either a fine particle sandblaster or by sanding it VERTICALLY on BOTH sides with a power sander and a fine grade paper.
If this is only an OUTER protective screen and the image is projected on the inner screen then DO NOT frost the replacement screen, just install it.
Posted on Mar 08, 2008
  • 513 Answers
Is there a flat plastic protective outer screen? If so then replacing that piece is less expensive then the lenticular lens(vertical lines on it), which would be at least double(depends if it comes with the fresnel lens or not). There's no good way to repair the scratch either way other than replacing the scratched piece. A light surface only scratch might be buffed out with little distortion to the picture. What you could do is get a special protective screen instead of replacing the outer screen(in case thats the only piece thats damaged), it might be a little more expensive, but worth it if you have kids, pets, or good parties planned. All options should be ~150$ and upwards. Good luck
Posted on Mar 20, 2006
Try lens doctor =)
Posted on Sep 03, 2009
4 Suggested Answers
  • 1153 Answers
SOURCE: Hitachi 50
Yes spider look inside, goto ctechnicians.com and email for answer.
Posted on Dec 22, 2007
  • 298 Answers
SOURCE: small scratches on tv screen, can I fix it?
The only way to completely get rid of the scratches is to replace the screen. If you want to get a new replacement protective screen for this model, here is a link from a major parts distributor:
RCA P61927 Replacement Part Protective Screen / Super Shield
Posted on Jan 16, 2009
  • 298 Answers
SOURCE: Help I need a replacement screen
You can find a new OEM RCA replacement lenticular screen and Fresnal screen (availble together as the screen assembly) for a model # R52WH73 from a major RCA distributor at the following links:
RCA R52WH73 Replacement Part Screen Assembly (Fresnal Screen w/ Lenticular Screen)
And here's a link for the protection screen if needed:
RCA R52WH73 Replacement Part Protection Screen / Super Shield
Posted on Apr 10, 2009
My hitachi 61 inch has lost its reD color. Any ideas??
Refurbished VIZIO E701i-A3 70" 1080p 120Hz Class Razor LED HDTV $ 899.00 at walmart ,because it looks like the power supply capacitors are going out red LEDs need more current to light up..and if you do not know how to repair electronics then you might consider another option .. :(
Oct 18, 2015 | Hitachi UltraVision 60VF820 TV
Scratched tv screen
there is no way to get cleared of the scratches done with sharp things....
it should be replaced fully which would cost much of the tv amount itself
May 14, 2008 | JVC AV-48P575 48" Rear Projection...
I have a Vizio LCD HDTV 1080 120hz 37", ModelSV370XT. (Bought 1/10/10 at Costco) The tv fell to the ground resulting in scratches appearing in the picture screen. You can't feel scratched on the TV surface...
The statement was not complete in the forum , hence I presume the LCD was damaged while it fell to the ground.
The cost of replacing a new LCD to a new set must be reviewed unless you are able to get one swapped from an old one.
Oct 23, 2010 | Vizio SV422XVT 42 in. LCD HDTV
Tv stop coming on
Disconnect the Power cable and the Rca cable from the Tv and press and hold the power button of the Tv for Thrity seconds and release the button and then replug the cables back again and restart the Tv, it should work.
May 12, 2010 | Vizio VW32L 32 in. LCD HDTV
Scratches on tv screen.
I have used clear plastic sheets and silicon tire dressing for smaller problems like this, but no idea how well it would work with a large screen TV. The westleys silicon tire shine smooths out the scratches, and you place the clear plastic sheet on top of that and work out any bubbles then tape the ends. It pretty much changes a standard screen into a glossy screen with the added benefit that you can always replace the sheet if it is damaged.
I usually get my clear plastic sheets packaged with the new LCD screens I purchase for repairs and I just keep them in storage.
Mar 12, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Scratched 32" screen
Honestly brother, there is not anything you can do about this. You have one of two options, #1 buy a new tv, or #2 deal with the scratches. If you call sharp, they will send you right out the door because their warranties do not cover physical damages in any way, shape, form, or fashion. Avoid yourself the embararssment and take one of those options. Take it from a person who knows. good luck 2 u
Feb 18, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Panasonic 61inch tv
mine did the same thing, call panasonic its the buld blown. just had mine replaced under warranty for 18 months after that bulb is 284.00 they've had a lot of problems with the bulbs in these tv's you can search gooogle for them
Oct 05, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
RCA P61927 61" Rear Projection Television Logo
12,104 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
