Question about Toastess TT-215P 2-Slice Toaster
Toastess -TT 215P 2 slice toaster
Tab to start toasting will not stay down to initiate toasting process.
  • cwuerfel Sep 09, 2008
    the toaster will work if I hold the bar down.. this was a $40. toaster and it is used only 4 months per year .. It is on its 3rd year...
    Sergeant:
    Champion:
  • 214 Answers
Just check the clip that locks the toaster.if not repairable manually you have to replace it
Posted on Sep 09, 2008
  • 1,879 Answers
    Brigadier General:
  • 3,614 Answers
It is possible the a spring or a lock has been detach or broken... have you try to open the unit and look for any damaged or broken parts.?
let me know
  • micromaster
    micromaster Sep 09, 2008
    try to look and check at this part, if it is still working and functioning well..
    illustrated photo shown below:
    fig1.
    Sergeant:
  • 264 Answers
The Lock to hold the bar has a problem.
  • 958 Answers
If you can open it up the thing that holds the tab down could have been used up already.
tnx 4 using fixya.
drcool
  • francis rivero Sep 09, 2008
    they are like clips that locks and releases as it senses heat.
    the hook are sometimes worn...
    tnx again.
    drcool
Black & Decker Toaster, model 3550: Pressing the handle down to lower the bread and start the toasting doesn't lock in place anymore. The toaster will toast, but you have to hold the handle down so...
The fact that pressing down the lever fails, means the toaster contact will not function and can not be repaired. Since a two slice toaster is only $15 at Target, why bother fixing a toaster?
Feb 20, 2018 | Black & Decker Toast-It-All Plus T3550...
When i push down the lever it doesn't stay down
remove the housing & you will probably notice the 2 ceramic pieces are burned out. (They maybe plastic) But these are the 2 pieces and the 2 long metal contact points that come together when the lever is pushed down. The 2 metal contact strips come together & make the eletronic connection to start the heating process. let me know if you find the parts.
May 02, 2010 | Black & Decker T2350 Toast-It-All Plus...
Krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
I just bought this kenmore 2 slice toaster and the toast lever won't stay down!?
Make sure it is set dark enough. Some toasters will not stay down if they are set too light.
Feb 11, 2010 | Kenmore 135101 2-Slice Toaster
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
Toaster does not stay held down to toast wct 708
there is a "contact switch" that when there is power in the system, it stays down. If hte contact switch is bad, it releases and will not stay down. COntact switch needs to be replaced, unfortuantely I have the same problem and can't seem to get the part.
Jun 12, 2009 | Waring WCT708 4-Slice Toaster
Sunbeam 3831 Toaster (2-slice) -- toast/carriage won't stay down
great ! its a great fealing when you save a appliance from the junkyard .
Mar 30, 2009 | Sunbeam 3831 2-Slice Toaster
Toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
The level of the toaster doesn't lock
I doubt if you can fix this without taking the unit apart. Usually it is not that difficult to remove the cover. Unplug the unit. Turn the toaster upside down and remove the screws holding the outside case on. The case usually slides off or by springing the bottom of the sides out you should be able to remove it. Once the cover is off it should be easy and obvious to fix the problem you described. When you have the unit secured reverse the order to assemble the unit and you should be back in business. Good luck.
Jul 17, 2006 | Toastess TT-415P 4-Slice Toaster
Toastess TT-215P 2-Slice Toaster Logo
181 people viewed this question
Top Toastess Kitchen Appliances - Others Experts
ray gallant
Tom Chichester
Bill Boyd
Are you a Toastess Kitchen Appliances - Other Expert? Answer questions, earn points and help others
