Question about InSTEP 10K Ultimate Double 11-KA285 Jogger
DUO CRUISER REPLACEMENT PARTS
I HAVE A IN STEP DOU CRUISER THAT NEEDS A NEW FRONT WHEEL AND POSSIBLY TIRE. TIRE SIZE IS 8 1/2 X 1.75. THE WHEEL IS BROKE. PLEASE HELP!!!!!!!!! I DONT THINK THE PRODUCT DESCRIPTION BELOW IS ACCURATE. THOSE WERE MY ONLY OPTIONS. ITS AN IN STEP DUO CRUISER.
THANKS,
TRACY
  • 1 more comment
  • Anonymous Nov 02, 2008
    I have a similar problem with finding Duo Cruiser parts - or lack thereof. They stopped making this model, and a phone call to InStep revealed that they no longer stock parts for this trailer. I need one of the 16" plastic wheels, as mine is warped and will no longer hold a tyre on it.
  • lilmizzj21 Nov 05, 2008
    Same here, I am looking for a replacement wheel as well. The rim part of the tire is bent and I am having problems locating a replacement wheel. I have been told by many bike shops it cannot be fixed and I will need to contact Instep. That was an unsuccessful call. Seems like this is a common problem!!
  • Anonymous Mar 21, 2009
    I also need a wheel. Instep was dismissive in helping me. I have to think there is one out there somewhere.
5 Suggested Answers
  • 37 Answers
SOURCE: new wheel in instep duo stroller needed (BACK WHEEL)
I should go to he Pram Shop where you bought it from, if it has closed down go to a Mothercare Shop or similar Pram Shop. They will be able to get you the information you need.
Posted on Apr 08, 2009
SOURCE: I got my duo cruiser from my brother,and I dont
bigbrad70 - I too had the very same problem. If your Duo cruiser has the spring hitch (a short 1.5 to 2 inch long spring mounted horizontaly in the frame just behind where it connets to the bike) then this is an easy fix. There are three parts needed. First looks something like a figure 8 with one large and one small hole. The second is a latch pin that goes through the first. The third is a washer with some tabs on one side. If you have these things then you have all the parts if not call the InStep customer service line
(800) 242-6110
Monday - Friday, 8am to 5pm (Central Standard Time)
And ask for the SA074 coupler.
If you do not have the spring hitch I think they have adifferent coupler but am not sure as mine has the spring hitch. As for the istallation just go to the InStep website and look up the owners manual for any of the older double bike trailers.
Hope this helps!
P.s. The coupler is back ordered until approximately June 28 but can be pre ordered (I am currently waiting for mine!)
Posted on Jun 11, 2009
ozark333
  • 396 Answers
SOURCE: InStep Duo Cruiser front wheel C clamp part needed.
Search eBay or Google it.
Posted on Apr 09, 2010
joeguest2
  • 2080 Answers
SOURCE: Where can I buy an
You can probably just get a standard 16 inch replacement inner tube or outer tire from any bike shop, both of which are usually pretty reasonably priced.
However, if you want the exact factory replacement parts then you can order them from the following link:
http://www.littletikes.com/consumerservice/ReplacementParts-detail.aspx?Product_ID=3322&
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Posted on Jun 06, 2011
Front tire size?
With a tube type laced wheel:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 TLA TUBE SIZE =Side Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a CHROME ALUMINUM PROFILE LACED RIM:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 MT TUBE SIZE = Center Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a Tubeless Cast Wheel:
WHEEL SIZE & POSITION = 16 in. - Front RIM SIZE & CONTOUR = T16 x 3.00 D Rim Valve hole diameter = .035 inches MH90x21 TIRE SIZE = DUNLOP D402 MT90B16 72H
Jul 11, 2014 | 2006 Harley Davidson FXSTDI Softail Deuce
What are the wheel and tire sizes front and rear for my 99 1200 sportster?
Fitment for 1999 XL Tubeless Cast Wheels:
Wheel Position and size = 19 inch Front; Rim Size and Contour = T19x 2.15 MT; Rim Valve Hole Diameter = 0.45 inch; Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16 x 3.00 D; Rim Valve Hole Diameter = 0.35 inch Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 100/90-V19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16x3.00 D; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 130/90-V16
Tire Fitment for 1999 XL Tube Laced Wheels:
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Tube Size = MJ90-19 Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16 x 3.00 D ; Tube Size = MT90-16; Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 21 Inch Front; Rim Size and Contour = T21x215 TLA; Tube Size = 3.00 x 21; Tire Size = Dunlop Touring ELITE II MH90 - 21 56H
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16x 3.00 D; Tube Size = MT90-16; Tire Size = Dunlop Touring ELITE II MT90 - B16
Tire Pressure - All Models:
Cold up to 300 Lb. Load (includes rider, passenger and cargo)
Front = 30 psi (2.1 bar)
Rear = 36 psi (2.5 bar)
Up to GVWR maximum load
Rear = 40 psi (2.8 bar)
Jul 07, 2014 | 1993 Harley Davidson XLH Sportster 883
Can i change tire size on my 2006 PT Cruiser
If you stay with the same height as the tires that came with it. You could go with a real big wheel and a super low profile tire or a small wheel with a tire that has a large side wall. You can go with any wide tire as long as it doesn't rub.
Nov 27, 2011 | 2006 Chrysler PT Cruiser
Slack in right front passenger tire. and roughness going down the highway . Is this a wheel bearing out?
Yes, jack the car up so there is no weight on the tire. Now grab the tire on top and bottom and shake. If there is movement, your wheel bearing needs replacing. Let us know if you want to try replacing it yourself.
Jul 24, 2011 | 2004 Chrysler PT Cruiser
I Had the tires rotated on my 2008 mazda cx9 at 13,000 miles in our local shop here,then i noticed a humming sound coming from front of vehicle and only when it approaches 50 to 55 mph,could it possibly be...
The noise is most likely caused by the different wear pattern on the tire that came from the rear of the car. The difference in the alignment between the front and rear suspension systems causes the tires to wear accordingly. It will take some time for the tires to wear in to their new environment. The noise should go away gradually. You should also check your tire pressure to make sure you don't have an improperly inflated tire.
Dec 16, 2010 | 2008 Mazda Cx 9
What size is a replacement wheel bearing for passenger front pt cruiser 2003
Wheel Bearing I.D. : 1.6535"
Wheel Bearing O.D. : 2.992"
Wheel Bearing Width : 1.5354"
Wheel Bearing Type : Double Row Tap
Sep 25, 2010 | 2003 Chrysler PT Cruiser
My InStep duo cruiser's front wheel is not working
My duo cruiser back wheel needs to be replacement how can I find whole new wheel?
May 27, 2010 | InSTEP Quick & EZ Bike Trailer
BATTERY
It's located inside the passenger side front wheel well in front of the front tire.You take it out through the wheel well once the tire is removed.
Jul 14, 2008 | 2002 Chrysler PT Cruiser
InSTEP 10K Ultimate Double 11-KA285 Jogger Logo
2,066 people viewed this question
Top InSTEP Baby Gear Experts
Jennifer Rock
Jennifer Rock
Are you an InSTEP Baby Gear Expert? Answer questions, earn points and help others
