Question about Samsung SCX 4200 All-In-One Laser Printer
Paper Jam 2
Display reads Paper Jam 2 Check iside but there is no paper jammed. Please help.
  • nelson338 Sep 27, 2008
    Display mostra "Paper Jam 2", em português, é claro, e trava a impressora. Help me, please!
  • juliuz Nov 14, 2008
    i have the same problem: paper jam 2, but there is no any paper inside/...
Thank u thank u, after reinstalling,doing all the bits that have been suggested everywhere on the net, absolutely nothing, 1 month of nothing,
Found this tip re back door, and yippeeeeeeee was paper there, removed and now working.
thankyou
mwahxxxxxxxxxxx
Posted on Oct 31, 2008
We had the same proplem - did you check there was no paper jammed when you opened the back cover?
Posted on Oct 11, 2008
Sir my printer problem is on printer menu write a clearing paper path what is this massage and give me solution.
Thank you contacting FixYa for your printer inquiry.
This error is associated with either a sheet of paper blocking the paper path or a partial piece of paper that blocks path or trips a sensor. The printer will usually throw up a error code 13.XX on the display and the XX is a number that will indicate where in the paper path this error most probably occurred. Just follow the steps for your error on the below chart.
This link will take you to the user guide which will be helpfull identifying components and providing guidelines for most of the helpful hints and things you will need to know about this printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Locate your error on the matrix below and follow the steps. Comment back if you need more help. Thank you again for contacting FixYa.
TF
HP Laserjet Error Codes 0 - 19 Message on printer Display Panel What it means. What to do. 13.XX PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation. 3.0 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation. 13.1 PAPER JAM OPEN INPUT TRAYS Paper-delay jam at paperfeed area. 1. Ensure that paper trays are loaded and adjusted properly so media can feed from the tray. It might be necessary to reduce the stack height of media in the tray. 2. Check the input area for obstructions such as media in the path. Also check to see if the registration assembly damaged or unseated. 3. Replace any defective sensors or flags. 4. Verify the media meets the specifications. 5. Check the pickup feed and separation rollers for unusual wear. Replace as needed. 6. Rotate the media in the input tray by 180° and/or turn it over On NX engines this is most likely the fuser flag or the ACPM. The ACPM has a photosensor hard-wired to the back of it. 13.10 PAPER JAM CHECK DUPLEXER Jam at duplexer. 1. Check the duplexer and the rear area of the printer for obstructions or damage. 2. Check the duplexer for proper operation. Replace the duplexer if a sensor is defective. On a 5si, 8000, or 8100 series laserjet a Duplex Jam can be caused by a tray 2 and 3 feed assembly failure. 13.14 For Laserjet 5si. This error is caused by a defective paper control PCA Replace paper control PCA. 13.2 PAPER JAM OPEN INPUT TRAYS Paper-stopped jam at paper-feed area. 1. Check the input area for obstructions such as paper in the path. Also check to see if the registration assembly is damaged or if the transfer roller is out of place. 2. Replace any defective sensors or flags. 3. Ensure the media does not exceed the maximum length. 4. If multiple sheets are feeding, it might be necessary to fan the media and reduce the stack height. Also, replace separation pad. 5. Verify that the fuser is properly installed. On NX engines this is an input jam. 13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on or when the top door was closed. 1. Remove all media in the paper path, and then open and close the top cover. 2. If the message persists after all media is removed: Check if media is jammed in the prefeed area. Replace any defective sensors or flags 13.21 DOOR OPEN JAM The top cover was open while printing. 1. Clear the jam and close the top door. 2. If the message persists, check the top door switch for proper operation. 13.5 PAPER JAM CHECK REAR DOOR Paper-delay jam at fuser. 1. Check the transfer roller and small media belt to ensure they are operating and can feed print media. 2. Check the paper path for obstructions at the transfer roller, toner cartridge, paper feed assembly, and fuser. 3. Replace any defective sensors or flags. 4. Turn the media stack over and/ or rotate it by 180° in the input tray. If still persists - replace fuser, then DC controller. 13.6 PAPER JAM CHECK REAR DOOR Paper-stopped jam at fuser. 1. Check the paper path for obstructions at the fuser and output/delivery area. 3. Replace any defective sensors or flags. 13.99 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation
Jun 09, 2011 | HP LaserJet 4350 Printer
Tip
How to Fix a Paper Jam in a Copy Machine
It seems inevitable that the copy machine will have a paper jam. You need the copies immediately, so how do you fix the jam? Luckily, ingenuity and a manual, can help you fix the problem yourself. Fixing a paper jam, can elevate you to hero status amongst your co-workers.
  1. Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
  2. Step 2 Turn off the copy machine before pulling out the paper.
  3. Step 3 Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
  4. Step 4 Check for any paper fragments and clean up any torn pieces.
  5. Step 5 Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
  6. Step 6 Replace the cover and paper tray and turn the machine back on.
  7. Step 7 Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push.
on Jul 14, 2010 | Office Equipment & Supplies
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For message 3.0 PAPER JAM [LOCATION]
means
Soln
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
Display reads - " jam in output bin " jam was
look at the output area, make sure that the paper lever is working. Sometimes they come loose after a jam.
Nov 21, 2010 | HP Laserjet CM 1312NFI Color Printer
Display reads paper jam 2 check inside
Open the Top Half of the Copier. The Scanner Section pops open by pushing up.
Underneath the Scanner Section is the Fuser Unit. Check in the Fuser Section, you will find paper Jam in the Fuser Section.
Apr 27, 2010 | Samsung CLX-6210FX Laser Printer
After clearing a paper jam incorrectly
Please check all places and follow all the steps here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&cc=us&lc=en&dlc=en&product=441125
Thank you
TechSaver
Feb 05, 2010 | HP Officejet 5610 All-In-One InkJet...
Paper Jam.
unplugg power cable from pritner. press adn hold 6 and # key on printer at same time. while holding them down plug it back in at same time. let pritner alligne afdter that. then it shud work fine
Dec 15, 2009 | HP Officejet 6500 Wireless All-in-One...
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
607 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
CheckitRight
CheckitRight
Paul King
Paul King
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
