Question about HP Compaq Presario 700Z Notebook
Lock-up My notebook periodically freezes up; sometimes within minutes, somtimes within hours. I have read in many forums that this is a common problem with this machine, but I've not run across any real solutions or even definite causes for this problem. The processor is AMD Athlon 1.5Ghz with 512Mb ram.
  • Anonymous Aug 12, 2008
    RAN SYSTEM RECOVERY AND WHEN REBOOTED, THE HP "WELCOME TO MICROSOFT WINDOWS" SCREEN LOCKS THE COMPUTER. WHAT IS THE SOLUTION?
  • 38 Answers
There is a known issue with these laptops that casues the CPU to not cool correctly. There was a fix supplied by Compaq that helps, but doesn't always totally correct the problem. This kit currently listed on Ebay under item #6862252317 Have you upgraded the memory? This can also cause issues, even when you use original Compaq ram. If you have, try running it without the upgrade and see if the lockups still occur.
Posted on Mar 22, 2006
  • 513 Answers
1.-update yours chipset driver via VIAarena 2..-update your se twister video driver 3.-remove from your laptop the fallowing file from micrisoft:Q317277 4.-disk index off 5.-video mem at 16MB. 6.-For myself, I am not using synaptics driver, I removed and auctomatically use microsoft touch pad driver.I increased my page file size to 950. Let me advise all you, it is a recipe, I tried upgrading only drivers, and then I get some freezing,only after I removed windows update file:Q317277 i got to be free of crashing also, please update your battery and firmware driver from compaq. in addition to all that, i took my laptop apart and replace the *lousy* thermal pad with arctic silver 3. Works like a charm now - only recommended if your warranty expired Good luck!
Posted on Mar 20, 2006
SOURCE:
The model of the BENQ Lcd Monitor is FP783 When I open the Monitor it is working around half an hour later on the screen become black but the the led is remain on. If you wait the screen never come back...
There are two boards that I would be checking, the power supply often has bulging capacitors that need to be replaced, the second concern is the inverter board has usually two three that need to be addressed, 'very common problems" the inverter energizes the back lights.
Jan 31, 2011 | BenQ FP783 17 IN LCD WEBCAM/SPK Monitor
Our detecter reads from 10 to 12 what levels are dangerous?
A Reading of 10-12 is nothing to be worried about.
Thirty-five ppm in an 8 hour period, is the maximum exposure allowed by OSHA in the workplace.
100 ppm Slight headache within 2 to 3 hours
400 ppm Frontal headache within 1 to 2 hours, Widespread headache within 2.5 to 3.5 hours
800 ppm Dizziness, nausea, convulsions within 45 minutes
1600 ppm Headache, dizziness and nausea within 20 minutes, Death within 1-2 hours.
3200 ppm Headache, dizziness and nausea within 5-10 minutes, Death within 1 hour.
6400 ppm Headache, dizziness and nausea within 1-2 minutes, Death within 25-30 minutes.
12,800 PPM Death within 1-3 minutes
Dec 17, 2010 | Kidde Nighthawk Combo Gas/co Detector
Winds up,Winds Down,CLICKWinds up,Winds Down,CLICK,THEN FREEZE!!!
presence of excessive virus or commonly spyware
May 16, 2009 | Maxtor Hard Drive
Kenmore top-freezer fridge makes a loud grinding noise for different periods of time - sometimes for 10 seconds and sometimes for 5+ minutes; and sometimes it won't happen for a week and other times it...
Remove the back wall of freezer. If the coils are frost solid youll need to advance the defrost timer(top inside refrige part) w/ a small flat screw driver, the defrost heater should glow red within a good minute. also youcan turn blade to be sure it is bracked and unobstructed.
Mar 21, 2009 | Kenmore Refrigerators
Toshiba Satellite M45-S265 Periodic Freezing, resumes, clock stop
do a virus scan
in add/remove uninstall any programs you no longer use
then do a disk defrag
then a scan disk
have you made any changes to system
please let me know if this has helped
don't forget to rate
Nov 30, 2008 | Toshiba Satellite M45-S265 Notebook
Acer Aspire 4720z Freezing Alot
increase the virtual memory and tell me whats the ram?
try and run 3 softwares from www.gur.in from the download section and run them in the same sequence
1) malaware bytes
2) dial a fix
3) superantispyware
Nov 01, 2008 | Acer Aspire 5004WLMi Notebook
Disk Read Error
Yes they will for a minmal fee of 180$ AHAHAHAH what a joke..
no they wont fix it for free.. it is cheaper to fix it yourself.
O you have to have the original recipet to even get it fixed if its in warranty.
Anyways get a lense cleaner they do have cd lens cleaners and try that first! 10$ 5quid your saves you a bunch!
Jun 22, 2008 | Sony Playstation 3 (PS3) Console
How could stop my phone from freezing?
Try reflashing it, although you need to backup contacts and other contents first before doing so,. Whats also nice with reflashing is it speeds up your phone and adds nifty features and nicer themes.
Read about it at motox.info
Dec 09, 2007 | Motorola Mobility MOTORAZR maxx V6...
Lock-up
If you can control + alt + delete and start over, then it may/may not work, then they're probably right and it's a software problem and not a hardware problem like overheating.
The first thing I would do is turn off all background programs. Here's how you do it:
Start
Run
Type "msconfig"
Hit 'Enter'
Go to the 'startup' tab
Click 'disable all'
I'd go back up the list at this point and recheck 'touchpad' if it's there. There often is such a thing on a laptop.
Click 'OK'
Restart the computer
When the computer starts back up, you'll have to check a box that appears that says you changed some system setting (or some such), just check and continue. You won't see it again unless you repeat the above process.
See if you continue to lockup.
If you don't, then you know one of those programs in that startup menu is causing the problem. You can repeat the above process and turn them on one by one (as opposed to disable all) (or leave them all off for a faster, smoother running machine!) if you want to and figure out what was causing the problem.
Nov 12, 2007 | Lenovo ThinkPad R51
Computers & Internet Logo
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
