Question about Mad Dog Multimedia (md-52xcdr) CD-RW Burner
Md52xcdr computer does not seem to recognize drive. The computer is an Emachine T5224.
    Problem Solver:
  • 8 Answers
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
Posted on Sep 18, 2008
I have a eMachine t5246. My hard drive went bad, very bad, couldn't get it to even get wiped out so. my eMachine disc won't start up. It is the operating disc but every time it says install and...
If the hard drive failed you will first need to replace it with a working hard drive. One that is done, power on the computer with the recovery disc is the drive and enter setup. It should say something like press F9 or F10 for Setup. Look through the menus for "Boot Order", make sure your CD/DVD drive is above hard drive. Save the changes and reboot, you should get a message "Press any key to boot to disc" or something similar, do so, and follow the prompts to re-install windows.
Jul 07, 2013 | Computers & Internet
Help with emachine T5224
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Jan 14, 2013 | eMachines Computers & Internet
I hear two beeps when i conect power suply on my emachine t5212 model
Very sorry about your son.
If you can't find the real problem, you can always put that hard drive into another PC to get the files. If so, be sure to looking to a potential "jumper" setting on that drive for it to be recognized.
May 05, 2012 | E-Machines T5212 PC Desktop
I have an emcahine T5224 it was given to me ive tried fixing it and determined its not the HDD because it loads the OS on my other computer and works just fine but for some reason it stops and says there...
You stated that it loads that OS on the other computer. Is this by taking out the hard drive and putting into another PC? If it is, then I would have thought there is h/w issue elsewhere in your PC...
Usually if you have a message saying that it could not load windows properly, it is an OS issue which I would recommend you fix by using your emachines recovery disks.
Hope that helps
Nov 11, 2010 | eMachines T5224 PC Desktop
I need the wiring diagram for emachine t5224 desktop pc
Do a Google search for " emachine t5224 manual", and get one. The manual should contain the wiring diagram showing how all components and cables are connected to the motherboard.
Oct 27, 2010 | Computers & Internet
Emachine el1200-07w model - optical cd/dvd burner drive is no longer working, as if the computer no longer recognizes the drive at all? Any way to fix this?
Try pushing the drive in the notebook and if the
drive exists outside the notebook, try pushing all the leads in the drive.
The first on worked with mine.
Jan 16, 2010 | E-Machines emachines (emachinees) CD-ROM...
How do i install a new graphics card in an emachine t5224?
If you're replacing the graphics card then it should go into the same slot as the one you are replacing. To do this, turn off the machine, remove the old card (if it's an AGP card they'll be a card lock on the inside end of the card where it plugs into slot). Remove the card lock, and then remove the card. Reinstall your new card. Keep in mind that your new card must be the same type as the old one AGP or PCI. The slots for these are different and you could damage the card and the slot.
Apr 10, 2009 | E-Machines eMachines Desktop PC
Replacement DVD-ROM drive
Hi there.
get hold of a boot cd or a windows install disk, set the boot options to boot from the cd drive, if the cd or dvd starts to boot and you get windows loading window then chances are that the lens on the drive is dirty and need cleaning, its also a possibility that the hard drive has bad sectors on it so setup can't write to the disk, hirens boot cd is a usefull tool to check for and recover bad sectors.
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | E-Machines M5305 Notebook
Sleep mode in emachine t5224
Hello:
Start the computer.
At the screen press F8 or find the screen to go to SAFE Boot mode. If you can get the computer to boot to safe mode, you can then fix the problem.
What probably happened is that the file for the sleep cache has become corrupted.
Search the net for other helps along this line.
Go slowly and find the right solution.
You can lose your data, if this is not done right.
thanks,
Aug 31, 2008 | Intel D865GBF Motherboard
Emachine T5224
Repeteadly Press F1 during boot. Then at the menu press F8 to go to advanced options. Then select System Recovery, and you can get into the recovery manager to restore the original factory system.
Jul 07, 2008 | E-Machines T2742 PC Desktop
Mad Dog Multimedia (md-52xcdr) CD-RW Burner Logo
134 people viewed this question
Top Mad Dog Multimedia Computers & Internet Experts
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
