Question about Cavs CDO-98E
HOW TO CONNECT SPEAKERS
HOW TO CONNECT A CAVS CDO-98 TO SPEAKERS
AND ALSO MICROPHONE HOOK UP
How do i hook up speakers? the light on the speaker is green and when i plug them in i get some pop up asking what device i plugges in.. in and out, line, mic, headphones.. help
you will need to connect your speakers to your computer then you will need to install them to your computer
usually at the back of a desktop computer there is three input plugs blue green pink/red or a usb connection depending on your speakers on a laptop usually a usb connection
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
also click start control panel sounds and audio devices then select voice then select volume from the microphone you can increase the volume or you can test your hardware in XP in W 7 click start control panel hardware and sound manage audio devices recording right click on microphone you can configure speech recognition
or you might have to boost
hope this helps you
Aug 30, 2011 | Acer (90.18612.36B) Computer Speakers
How to connect SONY DYNAMIC MICROPHONE F-V40 to JBL EON 515 15IN PWRD SPKR yahoo
Several ways. Easiest way is to just hook up mic to speaker via XLR and make sure on jbl speaker switch is set to Mic not Line. ( for volume ). Ideally you would hook mic to a console ( mixer ) and come out of mixers main out (l/r) to 2 separate jbl speakers ( being powered no amp is necessary ) for stereo!
Aug 26, 2011 | Audio Players & Recorders
I have a CAVS JB99 and would like to add a hard drive (EXTERNAL) to it. I need a hard drive that connects to an IDE ribbon cable. Where can I find one?
external hard drives do not connect to IDE cables. you may want to check this information again and make sure that you are not needing scsi
Jun 29, 2011 | Cavs JB-99 3-Disc CD Changer
How do I hook to dell
Basically, these speakers come with universal PL plugs, which means, you can connect them to any music source that has a headphones jack (just like an iPod, iPhone, walkman, discern etc...) you should have same phone jack in your DELL - use the green plug to the OUT jack (should have a little marking of an arrow out or little icon of headphones) the pink plug is for microphone.
Nov 13, 2010 | Boston Acoustics BA745 Computer Speakers
I have a compaq presario sr1214nx. The front has 3 audio hookups in blue pink and green. Where do i hook my speakers to?
The green is usually the audio out (stereo), connect the speakers to this.
The other two will be for microphone in (pink) and blue aux in (stereo).
If you look closely at the connectors you should see symbols for these connections.
Oct 24, 2010 | Audio Players & Recorders
HOW DO I HOOK THIS LOGITECH TO MY COMPUTER
Look on the back of your computer for GREEN and PINK and BLUE sockets.
PINK - plug a microphone into this socket.
BLUE -- plug an audio-device (CD-player, iPod, cassette deck) into this "audio-in" port
GREEN - plug your speakers into this "audio-out" port.
Connect the speakers to an AC power-outlet.
Oct 19, 2010 | Logitech X-530 Computer Speakers
I cannot get sound from my speakers. There is one prong on my right hand speaker but I do not know where to hook it.
Usually, the "line-out" from your computer's sound-card is a "stereo" output, but the cable only runs to one speaker.
Be sure to connect to "line-out" or "speaker-out",
not to "line-in" nor to "microphone-in".
A separate cable runs from that one speaker to the other speaker, using that single wire that you mentioned.
Sep 26, 2010 | Dell A215 Computer Speakers
Hooking up speakers.
Speakers do not normally connect to a microphone jack.
But if it has a headphone jack usually has a symbol like one of these.
http://symboldisco.wordpress.com/2009/02/
Then you could use that as the output to your speakers.
also if it has phono outputs on the back similar to these
http://www.smcelectronics.com/AUDCONN42.JPG
and they are marked nearby as OUTPUT you can also use those
Quality of sound will vary depending on the speaker quality itself.
if you have surround and any of the outputs as shown then with a little care it is still possible to hook up to that.
Don't try to connect INPUT sockets to speaker it will just not work.
You didn't give a specific model so I have only been able to give a generic answer.
Aug 18, 2009 | Emerson Televison & Video
Don't know how to hook them up
What a lovely daughter, how very nice of her,
here goes....straight for Mr. Koss
To Operate with AC Adapter
  1. Open battery compartment located at the back of both speakers and remove wires.
  2. Replace battery covers.
  3. Connect DUAL PLUG CONNECTOR on left speaker to right speaker at connection marked "TO LEFT SPEAKER."
  4. Connect remaining wire with 3.5mm plug to headphone jack on your audio source.
  5. Connect AC adapter (not included) to back of left speaker at connector marked "DC 6V." Plug remaining end of AC adapter into wall outlet. Be sure your AC adapter is built with the center pin as ("-") negative. Connect remaining wire with 3.5mm plug to the headphone jack on your audio source.
  6. Turn ON/OFF switch at back of right speaker to "ON."
  7. Set "INPUT SELECTOR" switch to audio source.
  8. Turn on audio source
  9. Adjust sound in the following ways: Turn volume control to desired level; push Bass Boost button located on right speaker to "ON" for added bass; push Treble Boost button on right speaker to "ON" for added treble
  10. Operating a microphone through your speakers require an additional 3.5mm plug to 3.5mm plug cable (included). Connect cable with 3.5mm straight plug to right speaker at input marked "MIC" on back of speaker. Plug the remaining 3.5mm L--plug into the mic input on audio source. Connect your microphone to the front of your speakers at "MIC" input (microphone not included)
Hope you have all of the skinny you need, good luck,
please leave a rating, thank you kindly
Apr 27, 2009 | Computers & Internet
Speakers
Hello vickiesbrown,
Yes you can, locate the external speaker jacks and plug your speaker plug into the jack. They are usually color coded.
Green (Speaker out) Pink (Microphone In) Blue (audio in),
You will be using the Green stereo jack to connect to your speakers.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 18, 2009 | JVC AV-48WP74 48" Rear Projection...
Cavs CDO-98E Logo
Top Cavs Televison & Video Experts
Electro Med Services...
Are you a Cavs Televison and Video Expert? Answer questions, earn points and help others
