Question about JVC AV-27980 27" TV
No power This TV has always worked fine, but all the sudden it has no power. I can't tell you anymore details since it cannot be turned on at all. We did try all obvious things like it being plugged in, and switching outlets. This was plugged into a power bar/strip (or whatever they're called) with 5 outlets on it and everything else plugged into it is working fine.
  • Anonymous Jul 06, 2008
    TV Has no power or doesn't show the power is on. Clicking sound inside
  • 513 Answers
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Could be several things- a 15 cent fuse, some solder joints that fail due to expansion and contraction of the circuit boards. Hard to say. Look for parts that look or smell burnt, might help you narrow it down. Good luck
Posted on Mar 20, 2006
Hi, I have a universal audiosonic remote control for my TV. Model JLR-6002. It was working fine and suddenly it not working anymore. How can I fix it???? Help Thanks
This is not the fault with its remote control. Just check its main power supply regulator section circuit, and the main board; if needy. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
May 09, 2014 | Televison & Video
Viore tv sound cuts out
Could be a failing power supply
Mar 12, 2014 | Televison & Video
Tv wont power on
If you have a light flashing, it might be the lamp has burned out.
Also the instant on power supply may have failed. Hard to tell anymore from description...
Dec 23, 2013 | Sony KDL46EX500 46 in. HD-Ready TV
My TV was FINE for months after I purchased it. Making zero changes to the HD cable box which was always set on 1080i. All of a sudden I get this Invalid format error out of nowhere. Don't tell me
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 22, 2012 | LG 32LG30 32 in. LCD HDTV
Sony KV-27S35 27" TV does not turn on anymore. What part(s) should I check/replace? Thanks in advance.
my sony 27" takes a very long time to power on, when it is turn on it works just fine, please tell me what is causing it to take so long to power on
Sep 24, 2010 | Sony KV-27S35 27" TV
KDL-32M4000 sony tv screen went black suddenly,
We are having the same problem! Whats the solution!!!?!?!?!?!!!?
Oct 18, 2009 | Sony KV-36FS100 36" TV
TC not turning on at all after switching from Video-TV input
by what you are saying looks like the picture tube has blown, I would need to look over it so best bet is to take to your local tv repair centre
Jun 22, 2009 | Daewoo DTQ-27S2FC 27" TV
My samsung plasma suddenly made clicking noises and tuned off
I wish to tell the world about the simple cheap fix for your plasma! . Please let me know if I helped. I have a 50" Plasma that deicded after a year it didn't want to turn on anymore. It just blinked red LED. Which made me see red! It took me a year to find this inexpesive fix I hope this information will be helpful to you.... These are spendy items and none of us were thinking that after a year (seems like a scam to me) the TV just won't turn on anymore.... Then they say your no longer covered under warranty or you are and they send you to some repair shop 1-2 hours away and always and I mean always tells you the part is on back order.
Lukster is right it is a power supply problem. However you don't need a new board nor do you need to pay someone a ridiculouse abount of money to fix this. I fixed mine for 40 cents.
You more than likey have bad capacitors.
Unplug the TV from power. Remove the back cover. (some models require a star srewdriver) You power supply board is right in the center. A bad cap is bulgded or raised. A good one is flat. caps have an X on the top of them. More than likely you will see a bulding or just straight raised edges on the X on the top of the caps. Cap 3300uf 10v is the ones you are looking for. Once you find them replace them with 3300uf 16v caps. If one cap is not raised replace it anyway. These caps need to be a higher voltage that why the tend to pop. 16V is plenty, don't go any higher in voltage than that.
The caps need to be soldered on. You have 2 options do it yourself or unplug all the wire harness from the board then unscrew the board take your power board (dont forget your new caps) down to a pc repair or tv repair and have them solder them on for you. It will take less than 10 minutes. I do recommend putting the board in an anti static bag. You can buy these caps at radio shack or buy them on ebay.
After you get it repaired replace your board plug all power supply wire harness back onto the board (I recommend numbering the wires as you remove them), replace the back panel cover. Plug her in and fire her up. and BAM it works. then turn it on and off a few times in complete amazement at how simple and inexspensive this was to do. Then get angry cause your repeated calls to tech support was wasted breath.
Semper Fi
Dec 16, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
JVC AV-27980 27" TV Logo
79 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
