Sony Cyber-Shot DSC-S90 Digital Camera
Problem for Sony Cyber-Shot DSC-S90 Digital Camera
SONY
By bella on Mar 18, 2006
i dropped my sony cyber-shot camera and the lense got pused in. everytime i turn it on all it is is a black screen that says "access". it makes werid noises and then after 10 minutes it says "turn the power off then on again" and i keep doing that but nothing happens.
Same Problem
Aug 29, 2008
-   I was taking pictures and having no problems turned it off and then on again to take some more pictures and keep getting the error Turn power off then on again when I do i just keep getting the same error...................-   bunwoofie
Best Solution
posted on Mar 20, 2006
Very Helpful)
silly girl
Rank: Wiz  Sony Expert
Rating: 81%, 3622 votes
from sony support site "The error TURN THE POWER OFF AND ON AGAIN will be displayed if the lens assembly is not operating correctly. Ensure fresh batteries are installed or make sure they are fully charged and then try turning the camera off and then back on.
NOTE: If the error message still occurs, service may be required."
I think you can pass on checking the battery. obviously your lens mechanism is somewhat busted, and you'll have to get it repaired.
I'm sorry theres nothing I can tell you which is DIY.
Use your warranty if valid.
Good luck
Was this helpful?
Yes
No
Solution #2
posted on Feb 13, 2007
Helpful)
JoeO700
Rank: Guru
Rating: 90%, 170 votes
The lens element is damaged internally and needs to be replaced as an entire unit. The camera runs through a "self check" each time it is powered up and it is detecting an error in the lens. Ship this unit to Sony in Laredo, TX. The warranty may not apply if they see there is impact damage to the lens. The flat rate repair charge will not apply here either due to physical damage to the lens element. be sure to request an estimate before the work is performed. Hope this helps you, we see this problem all the time with digital cameras that have lenses which extend during operation.
Joe Weibel
Custom Electronics
(customelectronics.org)
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Sony Cyber-Shot DSC-S90
Questions and Unsolved Problems for Sony Cyber-Shot DSC-S90
Do you recommend Sony Cyber-Shot DSC-S90 Digital Camera?
Answer
Answer
Camera has worked fine until the last few times I've used it. Pictures are not clear and have a... (More)
Answer
will not turn on. It has one green light on it
Answer
I change out the batteries between the rechargeable ones it came with and double A's. I can get it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
in , MD
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
