Question about Radio Communications
Antennas Uniden Bearcat BC148XLT
Are there any high powered antennas that will work with this scanner? I live in a semi-remote area and would like to pick up some municipal signals. Thanks.
  • Radio Commun... Master
  • 1,654 Answers
Height and placement of the antenna determines range. Also, check to see you have the antenna perpendicular to the ground (straight up), and place the antenna where it has 19" clear around it. (not up against a wall or other obstruction)
Placing the existing antenna higher, or replacing it with an external antenna would give you more range. A simple test before purchasing a new connector, coax and antenna for the scanner, would be to place the scanner where you think you would place an antenna and see if it gives you the range you desire.
External antennas are available from most any radio shop. (They would need to know what type of connector you need to connect the coax to the back of the unit.)
Posted on Sep 09, 2008
Uniden bearcat scanner bc142xl manual
Hello, the good news, though, is that all Uniden/Bearcat scanners in the 14X series are nearly identical in features and operation, so you can follow the link below to download/print the manual for the BC148XLT:
You need adobe reader to read the content.
Good luck
Dec 31, 2012 | Office Equipment & Supplies
Uniden bearcat scanner BC148XLT-1 Can't program it because it is locked out
Try manually unlocking each channel by selecting it and then pressing the LOCKOUT key. That will normally clear the channel for programming. If that doesn't fix the problem, power the scanner OFF, then press and hold the MANUAL, 2, and 9 keys while powering the unit ON. That should restore the scanner to its original factory settings.
Need the manual for your scanner? You can download and print it, at no cost, here:
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Bill B
Aug 11, 2010 | Radio Communications
I'am looking for scanner codes for Lancaster and Chester county for my Uniden Bearcat BC148XLT
You can find a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, at:
Bill B
Jul 05, 2010 | Uniden BC248CLT Base Scanner
I have a uniden bearcat scanner model#bc148xlt and it seems to not want to take the local frequencys and it comes up error when you hit the enter or e button
You didn't mention what frequencies you're trying to program. BC148XLT coverage ends at 512 MHz, so you will get the error message if you try to program anything above that. Also, you must be sure to include the decimal point when programming a frequency into the scanner. I hope this helps.
Need the manual for your scanner? You can download/print it here:
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 20, 2010 | Radio Communications
Lost codes for bearcat scanner BC148XLT-1
If you mean what is on a particular channel that say the police in your area is on then go to . Type in that complete address and it will bring you to a page where you click on the state you live in and if you want to go by city or county frequecies.
Sep 12, 2009 | Uniden Office Equipment & Supplies
Alot of static very little talking
Check you antenna on the scanner. You are describing loss of signal to the scanner. It could be the antenna, the antenna connector, the scanner its self.
Check everything over, Try a better antenna.
Aug 02, 2009 | Radio Communications
Need codes for scanner
Apr 16, 2009 | Uniden BC248CLT Base Scanner
Radio Communications Logo
259 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
