Candy CIW100T Washer, dryer
Stopped full of water. Need to try to clean filter, - where is it??
  • Jon-M Apr 13, 2009
    can't find the filter? to clean
DOES THE CANDY CIW 100 T HAVE A FILTER IF SO WHERE WOULD IT BE LOCATED
Posted on Jul 11, 2010
  • Chris
    Chris Dec 18, 2013
    No filter - you will have to take off the drain hose and clear it.
    New Friend:
Does anyone have an old CIW 100T washer/Dryer ??? I am trying to get hold of a new Door Release button - but they are now obsolete :(
Posted on Dec 18, 2013
Hi, My candy CIC60 tumble dryer has stopped drying and the empty water light is constantly on. The timer works. I have cleaned all filter,emptied water, checked for loose wires and I can not see a problem....
Tumble dryers are really not around my neck of the woods however I have studdied them just in case they do begin to show up around here. What turns on the light and kills power to the dryer when the water tank is full? A float switch. I bet that float switch is stuck. Probably something simple like that.
Nov 29, 2011 | Dryers
Washer/dryer problems
If you can locate the filter, remove and clean it.
They are usually found at the bottom front, behind a removable plastic panel.
Plz rate my solution,
Thanks.
Jan 13, 2009 | Candy CNW136 Front Load Washer/Dryer
Hi, I have a Candy CIW100T washing machine and its recently stopped draining the water aty the end of the cycle. Can you help please? Thanks
Check filter behind kick plate on bottom front of machine. Drain water out first by lowering drain hose into bowl or bucket.
Plz come back if further help required.
Dec 02, 2008 | Candy DQW150 Front Load Washer / Dryer
Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Jun 01, 2008 | Candy CDC266 Dryer
Will not drain
Try cleaning the filter as when this gets all clogged up the water doesnt drain thru the pump
Apr 24, 2008 | Candy AQ130 Front Load Washer
Candy 136cn washing machine wont empty
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Feb 01, 2008 | Candy CNW136 Front Load Washer/Dryer
Dryer not heating up
Hi Mally Try the following thread - http://www.fixya.com/problems-solutions/t103658,p117053/Bosch-Dryers.aspx It might also be relevant to your problem. Another pointer - - There might be a heat-sensitive fuse in the exhaust section of the dryer. The fuse is designed to turn off the heater element if the exhaust temperature gets too high. If this fuse is defective, it will keep the heater element from getting current. Good luck!
Jun 22, 2006 | Candy CNW156 Front Load Washer / Dryer
Washing Machines Logo
1,045 people viewed this question
Top Washing Machines Experts
