Question about Neovo E-19A 19" LCD Monitor
No display the stand by light goes from orange to green the no signal dispay comes on then goes...but the display does not turn on. Tried a different monitor with the same video card and it works. What's the problem
  • Leon Nelson Nov 12, 2007
    The monitor was working until two days ago when I truned it and the computer on I could hear the computer loading,but the monitor just showed the green "no signal" a few seconds and went black I conected the digital cable(no damaged pins in conector) from the monitor to my notebook computer with the same results. Whats wrong?
  • emaneri Nov 30, 2007
    i am having the same trouble. the monitor worked fine until today the green light is on (indicating its connected to a signal) whether its actually connected or not. and the monitor is blank
    Problem Solver:
  • 11 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cause of power going off: There is a bad 1000uF, 16V cap on the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35V cap for $2. This will work.
Why did the cap go bad? The cap is too close to a heat sink and over heated.
What does this cap do? This cap sends a signal to an IC which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor: These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart with a flat screw driver.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit board.
Unplug the monitor cords from the driver board and remove the screen.
Unscrew the mounting screws from the power supply board and remove.
You will need to pinch the plastic support in the middle of the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be on the side of the cap. It will be bulged up on the top. You will see burn marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the heat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Posted on Jan 01, 2009
  • 513 Answers
Are you using the digital connection?? If so try using both the analog and digital connection then set the digital as the Main monitor in your graphics card interface. Next time please include more details, such as - did the monitor ever work for you? Is this an installation problem? Good luck
Posted on Mar 20, 2006
Dell monitor starts well goes on a green light shows then it blacks out and the light on the front turns to amber(yelow)
The lamp goes "orange" when no "signal" is detected.
Check that the "video" cable is tightly-connected to both
the computer and the monitor.
Try the monitor on a different computer.
Try a borrowed monitor on your computer.
Try a different video-card inside your computer.
Mar 09, 2014 | Computers & Internet
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Monitor comes up shows "acer" then says no signal and goes black
This Problem is Acer(s) Monitors. Though it is a nuisance one fix That has work for many is the Unplugging after it goes back to Good (viewable) screen.
I have hooked mine up to an inexpensive Power strip to make it easier for me and just turn off at time indicated above and Viola Simple is as Simple does :)
Apr 24, 2009 | Acer X241Wsd Monitor
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
Pc wont read monitor
If you look at the monitor there will be an led light on the front that is always orange or yellow when the computer is off but still connected to the monitor. This led will turn green when the computer boots up, sometimes even showing a "no signal" display before boot. If you see the 'command line'  text during the boot process (video info, BIOS version, POST text, etc) then the monitor is being recognized by the computer. If that text goes away and the led goes back to orange then it is a driver or operating system problem. Pressing whatever key is prompted at the lower left of the display, if you have a display, like F1, F2, F10, Delete or whatever will get you to the setup program and all is good with the display/computer connection and a green light will stay on. If you never get that green led light then either the video card is bad or not seated properly
Nov 16, 2008 | HP PAVILION A6230N DESKTOP PC
Epson ELP-3300 powers up bulb light is green but stays on stand by
Hi djSilver
Try resetting the lamp timer.
This normally solves this problem.
Apr 22, 2008 | Office Equipment & Supplies
Pioneer PDP-435PG
I buy receiver of the plasma pdp 435pd my e-mail it is sergiofleitas@yahoo.com.ar
Apr 20, 2008 | Televison & Video
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
Neovo E-19A 19" LCD Monitor Logo
1,265 people viewed this question
Top Neovo Computers & Internet Experts
Steve Allison
Steve Allison
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
