While changing chanels the red on my tv went way out of registration. I tried the convergence but the red is out of whack too far to get back in. the red is crooked and doesn't line up straight up and down. all red lines are squiggly. sorry i dont have a better explanation.
Here is a similar problem to yours that might share a common fix:
http://www.fixya.com/ThreadView.aspx?thid=101765&prdid=231733
Please note the safety warning, and rate the answer so that other users know if it helped.
Good luck
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks! See link for more detail http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong?
Can anyone help me? Did i miss a step? Frustrated......Bruce
red projection is 2 in. off. tv is normal for about the first 3 min. then
convergence jump off.
