Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv fix??? did you ever get you tv fixed? and if so what was it?
  • RCA Master
  • 5,138 Answers
Whos TV are you taling about and what was the problem?
Posted on Sep 15, 2008
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2293282/magnavox-loud-static.html
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help · Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
ask.metafilter.com/17525/What-is-that-TV-Buzzing-Noise
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help - ecoustics.com
Dec 30, 2015 | Magnavox Televison & Video
How do I keep it on Digital? When I try and turn the channel, it goes to Video 1. It says Digital channel signal strength is low.
How to fix digital TV reception problems - Simplify Digital
www.simplifydigital.co.uk > Guides
SimplifydigitalJul 11, 2014 - This handy guide will help you fix simple digital TV reception issues with Freeview, satellite and cable TV set top boxes. ... If you're suffering from poor digital TV signal, it may be possible to fix reception issues quickly, at home. ... We're here to run you through how to fix TV ...
Digital television transition in the United States - Wikipedia ...
Dec 26, 2015 | Televison & Video
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
I want to fix my lg tv to a bracket but I don't know what screw/ bolts i can use and fix the bracket to the back of the tv thanks.
the screws are philips round head type fine thread u will need to go to a tv bracket dealer shop specify the size of the tv and u will be sold the bracket which comes with the standard screws for mounting
Jul 11, 2013 | Televison & Video
My display is arched on the top and bottom of display on my sony kp61hs10. Wanted to know a solution to fix this issue.
Convergence output ICs in your tv got defective and causing arched on top/bottom of screen.
Convergence output ICs will be replaced to fix tv problem. There is Convergence Repair Kit available along with photo instructions to fix tv problem and you can attempt to repair tv if you have little experience for that to understand those instructions. Or local tv repair shop will help you to fix the tv problem.
Jul 19, 2010 | Sony KP-61HS10 61" Rear Projection...
I have a rca f27442 tv and the picture is half
yes!!!! very common problem. soldering the vertical section and the grounds around the tuner section will fix it. guaranteed fix. for a quick fix, take off back and while tv is on, take the plastic side of screwdriver and tap tap tap the tuner section. see i told you that would fix it.
Nov 10, 2009 | RCA F27442 27" TV
My Thomson TV is completely not working
just open the tv and there will be a wire connected to tv screen look if it is fixed or not if itis fixed remove the print board below and look any of the soldering is dried and fix it
Jan 16, 2009 | Thomson LCDB 03B 27 in. Television
RCA F27683GY 27" TV
I bet both TV's are connected to cable TV? This was a problem and required different fixes. There was a law suit against RCA for this issue as they said there was nothing wrong with thier TV's that it was a cable issue. You will probably have to contact a local TV shop for repairs as just audio boards won't fix the problem.
Mar 22, 2007 | RCA F27683GY 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
23 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
