HP Pavilion a 1600n Starts by Itself
A shut down the computer every night. When I wake up in the morning, the computer is already on. In general, after is turned off, it will self restart after a few hours. I looked in the BIOS setup, but I couldn't find anything related to self-restart settings, or wake-up on modem (is not even connected to a phone line), or wake up on LAN (it is connected to a wired hub, which is connected to a router). There is no other computer on the network that is on at the time it wakes up by itself.
Please help me to save some energy!
Thank you.
    Problem Solver:
My DVD drive on my Hp 1600n pc does not work all the time I tried the cleaner with brushes that did not fix the problem what else can I try Thanks
Posted on Dec 08, 2009
Computer shuts down on its own
Open Control Panel, Power Options, set to High Performance, open Change Plan settings, open Change Advanced Power settings, set Sleep and Hibernate to Never, adjust advanced settings to your preference. Always shut down your computer when not in use, it will last longer, If you don't have a UPS, will help protect against power surges.
Feb 07, 2013 | HP Pavilion P2-1013W AMD DualCore 1.65G3GB...
HP printer will not wake up
NO but you could and probably should shut it down when not in use.
Oct 17, 2017 | HP Officejet 6500A Plus Wireless...
My laptop worked fine on night then in the morning i started having problems. These are the problem that i am having my with my HP Pavillion 6910us Laptop. 1. My laptop comes on but cuts off after 5 to 6...
Hi
At some point if you can get the computer to stay up for a while, you should go into control panel and check your
POWER settings. The other thing you should try if you haven't already is to shut the computer off and pull out the battery. Then after a minute re-install the battery and see
if that helps.
Good Luck
Joe
ps: If I come up with any ideas I will post.
Mar 04, 2017 | HP Pavilion Dv6910us Notebook
My HP Pavilion a 1600n wont let me long on goes to a black page tells me to press "r" for recovery i have no HP Pavilion a 1600n installation disc
k when the computer first boots up hit f8 or shift f8 to get to advance options . move arrows to last known good configuration. if that fails to get you on desk top you will most likely need to call hp and get replacement disks to reinstall the missing or currupted drivers. your NTloader is not reading from your master boot record that is why your getting this.
Nov 11, 2009 | HP Pavilion a1600n (882780776265) PC...
Cannot wake up computer after putting it to sleep -- HP Pavilion -- I have pressed every concievable key combination ? Computer may be waking, but monitor is blank.
I rebuild these systems all the time and I have to tell you I just shut off the hibernation which is what the problem is. Go to power options in the control panel and click the hibernation tab and uncheck the box. That way you save the disk space and the aggravation of trying to wake up the system. Let the computer go into standby if you want but you really need to turn off the hibernation...
Oct 05, 2009 | HP Pavilion dv6000z Notebook
Sud I turn off my p/c every night or just let it go to sleep
There is a lot of controversy over this issue, and it depends on how you use your PC. I use my PC for business, from 8-16 hrs a day. The best time to scan for viruses and perform other maintenance tasks is when I'm not using it, which happens to be while I'm sleeping. I set my PC go into hibernation, so it will 'wake up' at 3 a.m. and perform the full virus scan. There can also be problems with 'cold starts' on your hard drive if you turn it off every night. My recommendation is to leave it on, but make sure you have proper energy savers for the screen and hard disks on so it doesn't waste power.
May 30, 2009 | HP S7620N Pavilion Slimline Desktop PC -...
Startup problems
check your keyboard connection (unplug and plug again). If not works try another of same type.
Dec 24, 2007 | HP Compaq Presario V2000 Notebook
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
Computers & Internet Logo
301 people viewed this question
David Payne
David Payne
