Epson Stylus Photo 1280 InkJet Printer
Problem for Epson Stylus Photo 1280 InkJet Printer
Print Error
By iamaconsumer on Mar 17, 2006
When I print, it only prints about an inch, then shoots out the paper. The ink keeps going, like the printer is still printing. Sucks!
Same Problem
Aug 08, 2008
-   when on the machine by the time it want to calbrate it bring error sc 544 -   Guest
Jul 23, 2008
-   HP 1240 SOMETIMES ONLY PRINTS AN INCH, THEN WILL WORK OK FOR SUBSEQUENT PRINTS.-   the_hoist
May 01, 2008
-   Is not feeding the paper properly, only takes in about two inches, but it sounds like it is still printing inside the machine. Now I am getting a paper jam error but I cannot find a paper jam anywhere.-   Guest
Apr 08, 2008
-   It print about 2 inches, stop printing and cut the paper. Green light continues blinking, like receiving signal. If continues printing, white bars (1/4") appear expanding the picture.-   Guest
Apr 07, 2008
-   it prints abiut two pages and gives teh flashing Callaborate and Configure lights-   Guest
Best Solution
posted on Apr 19, 2008
Very Helpful)
AntonioCirio
Rank: Wiz  Computers & Networking  Expert
Rating: 82%, 87 votes
This problem is related with the paper sensor, located in the left tractor (frontal or rear, depends on what are you using). If you are able to disassembly the printer and the tractor, you can clean inside, cause this sensor, inside is a optical sensor, and the paper dust uses to block the led. If you are not so able, try to eschange the tractor. I recommend you to be so carefull to handle this printer, while you are disassembling it. May cause some uncalibrating of some systems.
Was this helpful?
Yes
No
Solution #2
posted on Mar 20, 2006
Somewhat Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3647 votes
make sure the thickness lever is set to 0.
To be on the safe side make sure you have the latest drivers, and check to make sure that you don't need to change the ink.
sometimes things like this happen when the printer registers a wrong ink level.
Hope this helps
Was this helpful?
Yes
No
Solution #3
posted on Apr 16, 2007
Not Helpful)
printerman
Rank: Master
Rating: 78%, 99 votes
delete printer, reinstall software...paper thickness level usually set a half.
Was this helpful?
Yes
No
Solution #4
posted on Aug 21, 2008
Not Rated)
lisainct
Rank: Apprentice
Rating: 0%, 0 votes
my hp 1240  fax says paper jam and there is no paper anywhere!! help
lisa
Was this helpful?
Yes
No
Solution #5
posted on Jun 15, 2008
Not Rated)
Guest
Rank: Apprentice  Computers & Networking  Expert
Rating: 0%, 0 votes
how to connect printer to other computer.
Solution #6
posted on Mar 17, 2008
Not Rated)
lexfi
Rank: Apprentice
Rating: 0%, 0 votes
i can not print id card in persona c11
Was this helpful?
Yes
No
Solution #7
posted on Dec 18, 2007
Not Rated)
Guest
Rating: 0%, 0 votes
i guess silly's solution for the above problem is not applicable on fx1170, coz epson stylus series are inkjets that uses ink while fx1170 uses only a ribbon tape which has no ink level indicator at all.
Solution #8
posted on Dec 12, 2007
Not Rated)
prashant8
Rank: Apprentice
Rating: 0%, 0 votes
printer is giving H4 error
Was this helpful?
Yes
No
Solution #9
posted on Nov 01, 2007
Not Rated)
Paxo
Rank: Apprentice
Rating: 0%, 0 votes
Sound like you have the printer driver set to Direct Thermal. Change the driver setting to Thermal Transfer and the ink will no longer come out with the label :)
Was this helpful?
Yes
No
Solution #10
posted on Oct 11, 2007
Not Rated)
qweasdzxc
Rank: Apprentice
Rating: 0%, 0 votes
to get printing commond start blicing pause light
Comments:
Oct 11, 2007
- to get test print and imiget blicing pause light.
Oct 11, 2007
- i think is problem label. you sure
Oct 11, 2007
- to get test print and imiget blicing Selection light
Oct 11, 2007
Was this helpful?
Yes
No
Solution #11
posted on Aug 14, 2007
Not Rated)
ineedfix
Rank: Apprentice
Rating: 0%, 0 votes
Might needs new roller. Your rollers is worn out.
Was this helpful?
Yes
No
Solution #12
posted on Jun 24, 2007
Not Rated)
printerman
Rank: Master
delete printer, reboot computer, re-install driver. you had a software hiccup, like you know!
Was this helpful?
Yes
No
Popular Solutions for Epson Stylus Photo 1280 InkJet
Questions and Unsolved Problems for Epson Stylus Photo 1280 InkJet
Do you recommend Epson Stylus Photo 1280 InkJet Printer?
Answer
Answer
My printer will not print on 12" paper even though the custom size is selected. (scrapbook 12x... (More)
Answer
Getting blue horizontal lines through all docs and photos. Just replaced both black and color... (More)
Answer
I put new ink in my epson stylus 1280 and its still saying my ink levels are low.
Answer
printouts have red lines throughout printed area. Have cleaned print head nozzles & run... (More)
15 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Apr 03, 2008
aligments problem
Comment by alab, posted on Mar 27, 2008
I have the same problem trying to print the tag but nothing printing keep running the tag he said.
Comment by roherdiaz, posted on Mar 27, 2008
the printer only print two and a half pages and then only sounds as if it was printing but the paper ejected is completely blank. the printer is Z33 Lexmark. Please help me.
Comment by Guest, posted on Mar 01, 2008
just changed ink cartridge & printer gives error message. working fine before
Comment by Guest, posted on Feb 26, 2008
When I print, it only prints about an inch, then shoots out about 9-10 papers.It was working well yesterday, dunno what happened today+can't use microsoft word anymore to print my labels(i need to print labels from microsoft word as well even if it does not generate a barecode) What is the solution? I am going crazy!!! Hope to hear from you really soon. Thanks
Comment by Guest, posted on Feb 25, 2008
I need to do a nozzle clean and cannot remember the program to use. HELP!
Comment by se726, posted on Feb 08, 2008
When printing, only prints the top 1/4 page and the rest is blank. Error message is Hardware error 0502.
Comment by patward, posted on Nov 28, 2007
printer makes loud clicking noises, paper comes half way out then printer shuts down. have checked he transparent strip behind the ink cartridges but didn't fix anything. what would you suggest.
Comment by Guest, posted on Nov 14, 2007
Printer prints first lines then the rest is blurred
Comment by Guest, posted on Nov 01, 2007
1st on a shipping label it printed the 1st 2 lines than nothing..tried again and now label advances but nothing is printing on the label..i did the 10 second test and the label advances but no writing or lines
Describe your Printers problem:
Related Products & Issues:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Limited Time Offer!
Epson Stylus Photo... Ink
Save up to 76% on
10% Off All Products.*
When you use coupon:
WINTERTEN, at checkout
Free Shipping on all U.S. Orders over $50
*exp 03.31.2010 excluding OEM ink
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
