Question about HP Compaq nx7010 Notebook
Touchpad issues The touchpad on this unit malfunctions from time to time. One of the following happens: 1. The cursor jumps all over the screen. 2. The touchpad turns itself on and off without notice. These just happen out of the blue. I haven't noticed anything that happens immediately prior to either one. I wish I had, then it might be a symptom that would help fix it. I'm stuck............. Any help is welcomed! Thanks!!
  • 51 Answers
Sounds like the touchpad needs to be replaced..some are attached to the plastic case you will have to replace the entire thing..not too expensive. if you can remove yourself, look @ the connector from pad to pc board make sure it's free of dirt and grime.
Posted on Sep 09, 2008
My cursor keeps jumping and moving the letters in my emails.
Step 1:
If you are a frequent user of a notebook or netbook computer, then you likely use a touchpad to navigate your computer's on-screen cursor. However, there are a number of issues that can cause your cursor to seem jumpy or unresponsive. To find what is causing these issues, you can troubleshoot both your hardware and your operating system and find a solution to the problem.
Turn your computer off and then clean your touchpad. Dampen a clean cloth with some isopropyl (rubbing) alcohol and then pat the pad dry with a paper towel. Even a small stain or sticky spot can throw off your touchpad's sensitivity, so it is vital that the pad remain clean of all extraneous substances. Re-calibrate your touchpad. Go to the hardware section of the "Mouse" utility (in the Control Panel) and find the device settings. There should be an "Advanced Settings" or "Calibration" utility under this tab. Follow the prompts to calibrate your touchpad for maximum efficiency. Use manual troubleshooting wizard. If you suspect that your computer's software or drivers are at fault, run the manual troubleshooting wizard. Go to the "Mouse" utility (in the Control Panel) and then go to the "Hardware" tab. Select your touchpad and then click on the "Troubleshoot..." button. Follow the prompts to troubleshoot software issues that could make your touchpad jumpy. Reduce cursor speed. In the "Mouse" utility, go to "Pointer options" and reduce the speed. This will prevent the cursor from going too fast when you move your finger on the touchpad, which could be the source of the "jumpy" effect.
Feb 15, 2013 | Toshiba Computers & Internet
Jumping cursors and letters
Step 1:
Feb 15, 2013 | Toshiba Satellite Computers & Internet
Cursor jumps while using touchpad.
> try to go to touchpad properties,you will be able to see there an option for tapping,you will be able to see there an option where you can turn off tapping while typing
Jun 21, 2010 | Dell Latitude C840 24X CD-R W/ DVD Combo...
CURSOR JUMPS OUT OF PLACE ,
Go to the touchpad properties, touchpad settings, Enable TouchCheck, set the slider to the far left (1/2 Second Delay) this will disable the touch pad while typing and enable it 1/2 second after you stop typing
Jun 01, 2010 | Dell Vostro 2510 Laptop
My Hp dv5 suddenly started giving problem when typing the cursor is jumping. what will be the reason? I cannot type continuously. I hav to search for the cursor where it goes. suddenly it disappears and...
This issue could be due to corrupt Touchpad drivers or corrupt Touchpad sensitivity settings or corrupt BIOS settings. To isolate this issue, please perform the steps provided below: 1. Uninstall and reinstall touchpad driver on the notebook. 2. Decrease the Touch Sensitivity of the Touchpad. If you are using Windows Vista on your notebook then you can follow the steps listed below for decreasing the touch sensitivity of the touchpad: a. Click Start and type ?Mouse? without quotes in Search field. b. Click on Mouse from the results list. c. This will open d. Click on Tapping tab in the Mouse Properties window. e. Click the Touch Sensitivity Button to launch Touchpad settings. f. Move the slider to the desired setting (in between Light touch to Hard touch) This will adjust the Touch sensitivity of the touch pad. Now check for the issue. 3. If the issue persists, then update BIOS on your notebook. To update BIOS, go to the HP drivers download page for your notebook model and then download and install the latest available BIOS update.
May 20, 2010 | HP Pavilion dv5000t Notebook
When I tap on the touch pad on a HP Pavilion dv7 cursor jumps
The touchpad is installed on HP notebook PCs.
You can "tap" and "double tap" your touchpad with your finger, and interact with the operating system in exactly the same way as clicking and double clicking on your mouse.
When using touchpad on your notebook PC, the cursor may jump, flicker, or double-click by itself.
Follow the recommendations in that HP document, or "disable" the TouchPad, if you don't like what it does.
May 12, 2010 | Computers & Internet
Cursor jumping and dell touchpad encumbering annoyances
try a usb mouse and dont't use pad, unless that is what you r doing, then uninstall drivers call if you have any ? 3363926682
Apr 14, 2010 | Dell F3534 Touchpad
Pavilion tx2110 touchpad jumps by itself
1. Its a normal thing, don't worry about it! (It happens mostly when you are using optical mouse.)
2. You can reinstall your Touch Pad / Mouse driver if you wish!
Jan 05, 2010 | HP Pavilion Tablet Notebook
Cursor arbitrarly jumps to wherever it may be sitting on the screen. makes typing very difficult
This is an issue with many laptop users because the touchpad is so sensitive that while typing the cursor can be moved when the hand comes into slight contact with the touchpad. You can go into the properties of the touchpad and try reducing the sensitivity and see if that helps or disable the touchpad in the device manager and use a usb mouse.
Oct 03, 2009 | Dell F3534 Touchpad
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
HP Compaq nx7010 Notebook Logo
66 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
