As i turn on my camera it makes a horrible 'trying' sound of the lens cap attempting to focus. And then as i switch to Photo or Video Mode i am once again bullied by the 'trying' noise and an enormous and blunt "FOCUS ERROR" written across the LCD. After i give up trying and turn the camera off; the lens is no longer covered. I believe it to be that the lens is no longer controlled and that its cover will no longer help protect him.
I have no idea what could have caused this problem, any help and absolutly any crazy ideas would be well appreciated and definately taken into some sort of consideration.
-   Hi folks,
I have a Finepix S9000, with approx 9400 on the clock.
The camea was working fine then, "Focus Error" appeared on the display and camera locks up. Removed batteries for 24hrs. no change.
Any help would be greatly appreciated.
Regards,
Roger-   faskarz
"FOCUS ERROR" is quite a common problem with fuji cameras, and they don't acknowledge it as of yet.
You could still try to reset the camera, either according to the manual, or by disconnecting all power supplies cables and cards for a few days. preferably both.
If you have a warranty use it before it ends.
Last resort would be to contact fuji and ask them about repair options, mention the fact that you know this problem is very common with their cameras. hope you find a solution thats not too expensive.
I saw the following advice on the internet, decided to try it and it worked then the message appeared again and now i cant get it done. Hope it works for you more than two days
Use a memory card reader and go to my computer, select the drive it is in and left click it. Select format. That did the trick for a couple of days. Oh BARE IN MIND FORMATING IT ERASES ALL PICTURES.
I have posted this on several web sites. The fix is easy for this camera. Just push in on the lens at the same time you turn it off. Resets the lens timing to focus. All done!
Comments:
Aug 16, 2009
- Look at solution 3 from elextrixman1 for the fix
Aug 16, 2009
- Push in on the glass lens part as you turn it off.
I'm using my Fuji Finepix 40i that I've loved for at least five years. It has NEVER been abused. Now...
(More)
I'm using my Fuji Finepix 40i that I've loved for at least five years. It has NEVER been abused. Now today, the ''lens cover'' warning comes on and will not let me photograph, yet it is open and I can visually see it open and close when I turn the camera off?
is there any one i can buy the spares from? and is there a manual that i can download that will...
(More)
is there any one i can buy the spares from? and is there a manual that i can download that will help. thanks
