Question about Sony KP-46V35 TV
Intermittent blank screen with r,g and b semi-circles at top of screen
The problem I have is ocassionally the screen will go blank with the red, green and blue semi-circles at the top of the screen. The audio is still good and the standby LED is blinking. Sometimes, the problem will correct itself. I start to see the semi-circles start to stretch across the too of the screen the picture pops back into place...only for this to happen again a few minutes later. Sometimes it never corrects itself and I turn the tv off for a few minutes. When I turn it back on, I get a good picture for a while but the problem returns. Any ideas on the cause of this problem?
  • mvcathey Sep 10, 2008
    Dan, the set has been off for several months due to the stated problem so I powered it up last night to see if the problem would show itself again. And it did not...yet. But a new problem was evident without any blinking of the LED. Each time I changed the channel the audio would switch immediately as expected but the video would take about 30 seconds to a minute to switch and again there was no blinking LED. It did not matter which channel I switched. Any ideas?
    Yes, the screen went blank and remained blank until the new channel appeared sometime later.
  • 4,234 Answers
The blinking standby light should be a help. It should be blinking a repeating code. Can you post that here please?
Thanks,
Dan
Posted on Sep 09, 2008
  • ABRsvcs Sep 10, 2008
    One question. When there was a delay in switchin the video, was there a blank screen between the channels?
    Thanks,
    Dan
My psp had a problem..they are always a green light but blank on the screen,,and no sound,,the psp are not functioning,,but yhe lcd screen are ok
Two sanario, 1. your psp is semi brinked. maybe when you try to downgrade your psp or when you tryied to flash the firmware. or 2. your psp is BRINKED! in which cause its a heavy paperweight.
If its semi brinked google repairing semi brink psp. you might need to us a pandora battery.
if its brinked.... buy a new one....
Mar 16, 2011 | Sony PlayStation® 3 (60 GB) Console
Distorted picture
You have a convergence problem.On this model you can change the convergence amp board which has the convergence IC's on it making it an easy repair.
Oct 06, 2007 | Samsung HC-P4752W 47" Rear Projection...
Need to know how to hook up to 220 power supply what wires go where we got a red wire,black,white, and green which is ground can u help?
L1
L2
L3
Neutral
Earth
North America
Black
Red
Blue
White
Green
There is no blue cable in a 220V, so you have only; white, black, red and ground always green colored wire.
Looking your plug frontal side.
Green Ground on top (semi-circle)
black on left
red on right
white on bottom (neutral).
Jan 10, 2011 | Miller Bobcat 3 Phase Welder Generator...
I can see a semi circle on my screen
If you see a white outline of a semi circle it is a pressure mark caused by something pressing down on that part of the screen. Nothing can be done except to replace the LCD if it bothers you. Good Luck!
May 30, 2010 | Dell Inspiron Mini 10 Notebook
The colors aren't matching up I have green semi
Yoy have convergence issue with tv,try the magic focus/touch focus or manual adjustment in the menu under convergence, if can't be adjusted then your convergence ckt is the problem,you will need a tv tech to repair it.
Mar 19, 2010 | Mitsubishi VS-50605 50" Rear Projection...
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
53UWX10B Red giving problems
Good Day,
Welcome to the world of having a convergence circuit problem. There two things you can do; get it repaired by a Factory Authorized Service Center or repair it your self. Purchase KIT 10 from B&D Enterprises, 1-800-458-6053. The kit has everything you will need except soldering equipment and experience. Good Luck, big IRISH.
Sep 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Sony Ericsson K810i Cam Blank
Hi..
Sounds like there could be a manufacturer defect so if the phone is still within the warranty, I would definitely contact them and let them know about the green circle and such. I've never seen anything like that before on any of my Sony phones..
Hope this helps..
donster74
Feb 11, 2008 | Sony Ericsson K800i Cellular Phone
Green semi-circle of lines on Samsung 55" HDTV (projection)
I believe i have the same problem myself. When my TV is on any of the Component Inputs without my DVD player turned on i usually get the normal green screen. But now that is a dip in the green at the top of the screen from the top left to almost the top right and black pushing down on the dip. Almost like a green curtain was sagging at the top and you can see the black behind it. It does this on every input and distorts every picture you see. The distorted picture has all the green slightly off from where the rest of the picture is and where the dip at the top of the screen is there is somtimes purple instead of black.
I know the basics of how the picture gets onto the screen and its my guess that the Green "gun" for lack of a better term and somhow come loose, or been missaligned to a great extent. I would love to find an answer to this problem, and anyones best guess as to how much a repair man will charge, just so i know the ballpark.
Jan 31, 2008 | Samsung HCN653W 65" Rear Projection...
Televison & Video Logo
111 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
