Hi good day "Topsychicc"
you can easily fix this problem by yourself, find your Dell inspiron 6400 laptop driver from their website,find your "service tag" from bottom of your laptop then search driver from their website mentioned below http://support.dell.com/support/downloads/
then download and install your audio driver...
Thank you,,,,Please rate me
Hi, you can download a new audio driver here:
http://support.dell.com/support/downloads/driverslist.aspx?&l=en&s=gen&os=WW1&osl=en&SystemID=INSPIRONI6400/E1505
The files have to be unziped before installation.
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer dont forget to vote
hope this helps
hope this helps
