JVC KD-SX780 CD Player
Problem for JVC KD-SX780 CD Player
KD-SX780
By nicknack on Mar 17, 2006
Alright,
this is a lengthy problem so please bear with me, and I will cut to the chase.
stereo worked fine when I turned the car off. Next morning it ran and died seconds later. But when I accelerate it runs briefly. I am a second year mechatronics student @ UNB so I asked my EE prof what he thought. He said that with all the symptoms he thinks that there is something burned up within the amplification modual that sends power out to the speakers. Because the stereo displays cd and radio function the equalizer is on and running I can switch through songs and radio stations and everything functions as if it would normally. He feels that when the car accelerates the stereo is getting an access surge of current that would briefly succeed any burned up component.
I guess what my question is, have you encountered this problem beforeand could you inform me as to which component needs replacing and diagram to find it.
Best Solution
posted on Mar 24, 2006
Helpful)
techman
Rank: Guru  JVC Expert
Rating: 86%, 7668 votes
Yep May sound silly but do you have a dedicated line for youe B+ going to your amp section or Main B+ Line??? you as well should not I found from expereance use the factory B+ line to run an extras power type radio as its not really built or made for that. also Make sure you double and tripe check the grounds going to the radio as well and do not also use the factory grounds as they should as well be dedicated and that means right from the battery for the grounds.. Now a simple but very good way of getting a dedicated B+ line thats a switched type (only one when the keys on) Is to use a 12 volt 25 to 30 contact rating relay and use the cars original power wire for the 12+ for the relay coil and the ground from the original radio. Now one side of the relay can go directly to the battery and the on side when active can go to the radio.. simple but very efective.
Was this helpful?
Yes
No
Popular Solutions for JVC KD-SX780 CD Player
Questions and Unsolved Problems for JVC KD-SX780 CD Player
Do you recommend JVC KD-SX780 CD Player?
Answer
Answer
trying to find a wiring diagram for kenwood kdc-x579 Color codes for wires What color wires is for... (More)
Answer
don't have wiring harness for pioneer deh-1800 car stereo. what do each of the pins in back go to?
Answer
I forgot my security code for Kenwood KDC-X492 receiver. Can you help?
Answer
it powers on when you hit ther display button but nothing after that ive tried every thing.
Answer
jvc kd-sx780 all of the sudden--just stopped working.. if you touch the "display"... (More)
Describe your In Dash Receivers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top In Dash Receiver Experts
Top Audio & Video Equipment Repairmen
in , CO
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
