Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi WD-62525 Red Status Light After Cap Replacement
I just finished replacing 6 CAPs on my power board after having the flashing green power led symptom.
After putting the set back together I get the steady red status led and the error code indicates 41 (short detected).
Any suggestions.
PS. I replaced two caps on the power board 6 months ago and the TV worked fine after words.
  • zakupy Oct 13, 2008
    I have Mitsubishi 62525 and blinking green light on front panel. I read a lot of 4 capacitors to be replaced. Are there any instructions available how to get to the board. I opened TV's the back panel but have no idea how to get to capacitors.
  • rlwillis1977 Feb 04, 2009
    I have a WD62525. I was watching it one day and it just shut off and the status light went red. I spoke to a tech who said it was likely a set of caps on the power board. He came to my house and got code 41 out of it and found a 15A fuse blown on the power board but not the cause of a short.
  • 84 Answers
Mitsubishi V26 error code 41 with solid red status indicator is caused by leakage from capacitors C9A37 and C9A38 (3300mf/16v). The result is a bad fuse F9A02 (15amp pico) which reports error code 41 indicating short protect. The Mits part number is 283P144040 but any PICO 15a fuse will work.
Bill W.
Posted on Mar 14, 2011
  • 3 Answers
A steady red light: there is a short on the DVI cable from FMT to DMD disconnected
Posted on Sep 29, 2008
2 Suggested Answers
  • 8617 Answers
SOURCE: Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Posted on Sep 11, 2008
Mitsubishi WD-62525 3 fast red lights then 1 long repeating
Not sure if they can be swapped may want to get the schematics or service manuals and check
Apr 29, 2013 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS 55513...
sounds like the power supply board is unhappy
Mar 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Kfwe50a1 will not start, green light comes on and then flashes red 6 times
Hi Keith,
6 flashes of the led light is an error code and the unit will not fire-up unless isolated the faulty parts.
To confirm if it is the real fault, unplug the unit from the outlet for 15 minutes and then plug it back in and check if the symptoms still persist.
Your unit has a self diagnostic screen that can be access by pressing in rapid sequence "Display", "Channel 5", "Volume (-)", "Power" on the remote control while the unit is in standby mode or the led light stops from blinking.
Self diagnostic screen will be display. Error code will be display together with numerical "0" means no fault detected and "1" means fault detected.
You will see "6 : LOWB with a numerical "1" on the screen, this is an error code for 6 flashes of the led light.
After you've confirmed that the the error code is "6 blinks/ LOWB error code", then the G1 board (Power supply board) is faulty. LOWB error code means that there's a malfunction on the 6Volts output of the G1 board.
To isolate the fault on the G1 board, you must have a skills on electronics troubleshooting, soldering and desoldering parts on the board, have necessary tools and test instrument. If you can't troubleshoot the unit yourself, don't worry, there's a DIY solution so that you can save money for the service fee of a TV technician. You may replaced the entire G1 board(part no. A-1087-323-A), this is more convenient if you are going to do-it-yourself because no troubleshooting and soldering required. I would advice you to obtain the board from your nearest Sony service center because this board is currently not available online.
Please let me know if you need further assistance.
Ratings and feedback is highly appreciated.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Nov 08, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Blinking green timer light after power outage.
Failed capacitors on the DM and the Power boards. You can get the V26 Chassis DM/ Power repair kit from which contains the replacement caps and the CD with instructions.
Aug 06, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Blinking green light in front of tv and no picture. On a Mitsubishi 62525 projection tv
This problem is bad capacitors on several circuit boards inside. They are solder in parts and replacement requires extensive disassembly. Repair estimate = 200-500$
If you can solder and have disassembly skills, I can talk you through the repair with about $30 in parts and a few hours of time. Let me know if I can be of more assistance.
8-12 1000uf 16v caps = replace with 680uf @16v
possible 2 bad caps on power supply too.. 2200uf or 3300uf I cannot remember. All are labeled and will be obvious. Check my bulletin on bulged caps.
Jun 04, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have a mitsubishi wd62725 green flashing led non stop replaced all the bad caps, 2 big and 4 smaller on power 4 1000u on fmt and 4 1000u on the dm board still getting the non stop led if i boot up with...
You can press the "DEVICE" and "MENU" keys on the front of the TV (not the remote) and the TV should flash an error code. Here is a chart.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
If the code is lets say 36 the LED will flash 3 times then pause then 6 flashes.
May 22, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Flashing green LED on my Hanns-G HX191D
Common problems on monitors are due to capacitors in the power supply/inverter circuits failed, you need to open it up and look inside for caps with bulging top/seal first and post back what you see so we can guide you further, see failed monitors due to bad caps:
Mar 17, 2010 | Hannspree HANNS.G HX191D 19" LCD Monitor
Have green light from hell replaced caps on power supply stillhave green light from hell wich board is the dm board
Chassi will have to be removed and sent to Mitsubishi for rebuild. It takes them a long time to get it back to you.
Nov 23, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD62525 Dead NO Power-Won't turn on
Don't think dm board will solve your issue, might want to check power board for buldging caps.
Aug 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Constant flashing green light
I had the same problem. When I checked the lamp (that was only 6 months old) it looked good. I had a tech come out and he put in a new lamp and solved the problem.
Good Luck!
Apr 14, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
1,003 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
