Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Water despenser not working.
The icemaker works just fine. I changed the water filter and it still does not work.
  • Bigtimerjoe Sep 12, 2008
    What is a compraser ?
    President:
  • 1,952 Answers
Check the correct fix of water filter i think compraser is not work
Posted on Sep 09, 2008
The water dispenser on my kenmore side by side has stoped working.
I have no solution, I need help getting onto facebook. Please update your page giving us an area to log in for those of us who are already members.
Feb 26, 2014 | Computers & Internet
Water wont despense
Note: Always make sure your filter is current if you have one. Not doing so will cause water to not despence properly
Pull the machine out and remove the lower back cover. Locate the water valve. With the water turned on and connected remove the 5/16" water line (the bigger one) and then have someone else press the water in the door. If the cylinoid is operating correctly it should spray water out.If so, you just verified that the valve and electrical portions are working properly and either the filter is bad or the resevoir, , located inside the lower refrigerator side is frozen. If no water comes out but the valve vibrates, then the valve is bad. If no water and no vibration, continue reading.With the machine plugged in but the wires that go to the valve for the dispenser off take a volt meter and place a lead to each wire and have someone press the panel in the door as if getting water. The reading should go from 0 to around 115-120 a/c.If your not getting electricity down there at anytime than thje door switch is bad.
Testing the ice maker:
As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in.
May 19, 2012 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Kenmore refrig mod # 507920. Icemaker working
check to see if the hose going into icemaker is frozen. unclog it
Aug 24, 2009 | Refrigerators
The water despenser works but the icemaker doesn't
The most popular problem area is the fill tube by the icemaker. Check for an ice build up inside of the tube. If that isn't the problem, you must ck the coils on the filter valve and the coils on the supply valve with an ohm meter. Check for kinked water lines, leaky water lines etc. An after thought, make sure that the icemaker itself hasn't got a huge bunch of ice it built up and can't dump out.
May 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
My icemaker works fine, but does not dispense water from the door
Had same problem, my despenser water line was froze in the door. Here is the steps I went through to fix. http://www.fixya.com/support/t1383727-got_ice_but_no_water
Dec 02, 2008 | GE GSS25LGM Side by Side Refrigerator
Water despenser
hi there,
check to see if you have a leak in the water line. the line runs from the wall to the icemaker. do you have any leaks on the inside of the door? any frost build up? im assuming that you have a side by side fridge with an icemaker.
Oct 11, 2008 | Refrigerators
Water Depenser
As far as I know, all icemaker-equipped fridges have a filter in line with the water supply and if you have any sediment in yur lines, the filter may be clogged and due for a change.
Aug 26, 2008 | Frigidaire FRS3R5EMB Side by Side...
Icemaker not getting water
water despenser is working fine,but ice maker is not working
2 yr old maytag french door refridgerator
Dec 27, 2006 | KitchenAid KSCS25FKSS Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
75 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
