Question about Maxtor MaXLine Plus II 250 GB Hard Drive
Can't find the cause for clicking noise and BSOD
Sometimes, with no apparent reason, there's a loud repetitive clicking noise coming from the disk. I ran several diagnosis tools and none found any bad sectors or things like that. I ran Maxtor's PowerMax and anything you can imagine, defragged the disk and nothing happened. Some time ago I changed this drive to slave, and booted WinXP from another HD. Now I just access files on the problematic drive, not the system anymore, and the blue screens of death stopped appearing. Anyway, although the problem got less frequent, it is still there. I used to believe that excess heat was causing this, because my case was always displaying warnings. I boutgh a HDD cooler and at the first boot the noises came up again. I dont know if it has anything to do with it, but I'm a pretty heavy bittorrent user, first with BitComet and now with uTorrent.
  • 513 Answers
From what I've read, the "clicking" is a sign that the hard drive is about to fail. The cause is using two devices (hard drives, CD-ROM drives, etc.) with different read/write speeds on the same IDE cable. For instance, you MUST not have an ATA100, ATA66, or ATA33 hard drive or CD-ROM drive on the same IDE cable as a faster ATA133 hard drive. Hope this helps
Posted on Mar 19, 2006
What is the cause of a very loud, repetitive noise during spin cycle?
Sounds like the drum mounts are worn causing unbalance.
Sep 13, 2014 | Amana Washing Machines
Got blue screen.. Trying to restart, but it is going in a loop on all different start up modes. What can i do?
If your computer came with a recovery disk, insert the disk into the optical drive and power the laptop down. On the initial boot screen, select BOOT Options by pressing, typically, F4, F8, F10, or F12 (Each computer is different).
Tell your computer to start up using the "CD/DVD", and run Windows Repair from the recovery disk.
If you do not have a recover disk, remove the battery and the power cord for a few minutes (Let all the power drain out of the motherboard, replace and restart.
As a last resort, you may have to reinstall Windows. If you install Windows 7, there is an option when selecting a drive to install on (You can't miss it) that will backup your files prior to the installation.
Apr 12, 2011 | Acer Aspire One PC Notebook
My hard drive just clicks and will not mount.
If you hear a repetitive clicking noise from the disk, I'm afraid it will no longer work. That is an indication that the disk's heads are failing to read from the disk, or in other words that the disk is faulty.
If it's still under warranty you could (and should) get it replaced. Hope you have a backup of all the important files in it!
Mar 13, 2011 | Kingwin EZDock EZD2535 Drive Dock External...
Back wheels make a loud clicking noise
Hi. Loud clicking noises from the rear wheels are usually caused by movement of the square steel key that fits into a groove on the axle inside the wheel hub. This is what drives the wheels.
You will probably get a click for each revolution of the wheels.
To fix it, remove the rear wheels and wipe a thin smear of grease on the key and axle, then replace the wheels.
The grease will allow the key to move slightly without making a noise, and help stop it from wearing.
It sometimes helps to also remove the front wheels, and wipe a thin smear of grease onto the front stub axles. There is no key in the front hubs, but the grease helps to prevent the bearings siezing on to the axles.
Good luck. Neil.
Jun 24, 2010 | Pride New Mobility Legend 4 Wheel Scooter
Car wont start but the lights, radio and everything battery operated comes on but it just makes a click noise when trying to start engine
If you can hear a click (quite loud) from the engine compartment, but the starter won't crank, this also could be caused by discharged battery. Battery problems - Discharged or dead battery is one of the possible reasons for a car not to start. Very common is the situation when we forget to turn the lights off overnight (the dome light, for example), which causes the battery to drain. In this case when attempting to start a car, all you will probably hear will be a clicking noise - there won't be enough power to turn the starter. Here is the simple way to check if the battery is discharged: Turn the ignition on. With the engine off, turn the windshield wipers on. If they move way too slow, much slower than usual, the battery is probably discharged. Also look at the dashboard lights - if they appear very dim, the battery is probably discharged.
If the battery is relatively new, it can be recharged. All you need to do is to boost your car and let the engine run for a while to charge the battery.
However if your battery is more than three-four years old, you will probably need to buy a new one. Sometimes, an old battery may even die with no apparent reason, even if the day before it was OK.
If the battery is OK, the starter solenoid, starter cables or the starter motor itself could be a problem.
Check it and tell us news.
Mar 29, 2010 | 2000 Buick LeSabre
When driving getting a loud clicking noise coming from the drivers side front wheel?
Is this only when turning and accelerating? If so it si your CV axle shaft on that side. Very common in FWD cars. The clicking is the shaft not being lubricated due to the boot that holds the grease (where the axle flexes for turning) being worn/torn and needs to be replace otherwise after extended driving will cause the shaft to break loose leaving the car disabled. Sometimes when the axle breaks it snaps back and damages the trans pan so its very important to have it replaced. The axle cost about $60-$100 and labor should be about 45min-1hr for any certified shop to replace. Sometimes you can get it replaced for $150-$250 total depending on what shop you go to, shop around....
Oct 29, 2009 | 1997 Volkswagen Golf
Loud fan noise
The fan noise has two reasons: one is that ice forms around them causing strain on the disk brush in the middle, which wares down the brush causing the fan to go out of balance, this causing the loud whinning and sometimes high pitched squilling. This happens when the unit is six months to a year old. The first thing that is suggested by the manufacturer is to let the unit be unplugged for twenty-four hours, allowing the ice to melt from around the fans. It has been my experience that this is only a short term fix. You can repeat this every other month until the revolutions per minute of the fans is so reduced that they no longer supply enough air ciculation to cool the refrigerator or the freezer. The solution to this problem is to replace these fans about once a year. Unless the noise does not bother you.
Jul 18, 2009 | LG Refrigerators
Small relay on PCB making loud noises for no reason
There should be a circuit designation on the PC board for this part. Can you please post that. I'll lok up that part in the manual and try to figure out what is happening.
Thanks,
Dan
May 11, 2009 | Audio Players & Recorders
Problem with ps3 blu ray drive making a loud clicking noise
I can help you with this, no prob.
which PS3 do you have?
Mar 10, 2009 | Sony Playstation 3 (PS3) Console
Maxtor MaXLine Plus II 250 GB Hard Drive Logo
241 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
