Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
WD Passport My passport just stopped working. I have a HP laptop that runs Vista. The passport worked fine until yesterday. I get a message when trying to run the WD..exe sync that a problem caused the WD not to work. I went to the WD website and downloaded the exe file and it worked fine but it looked like it started from scratch. This morning nothing - same error message. What's up with this thing? How do I get it back on track? Thanks
  • raj_bhardwaj Jan 17, 2009
    I have Microsoft Vista on Toshiba and I was able to run WD Sync but now a days, whenever I start WD sync I get an error that WD SYnc stopped working. It seems it has something to do with Windows Live OneCare program I instaled on my laptop.
    Can someone please help me?
    Thx
I need the instalation
Posted on Oct 05, 2008
Hi there, I just bought my WD My passport 500gb usb 2.0 last november, it was fine until yesterday when I mistakenly pulled out the cable while it was installing the WD smartware on the laptop, since then...
1 If the warranty is valid> get another drive and install it according to the instruction set. the hassle is better than trying to fix what is broken or defective without the tools to do so.
Feb 12, 2011 | Western Digital My Passport Essential...
I have a WD Passport drive that I want to use through a Targus mini USB hub. The Passport drive has power, but it will not install through the hub. Apparently wants a driver and apparently they don't have...
The reason your full sized drive works fine and the passport doesn't is that the full sized drive has it's own power supply and only uses the USB for data transfer. The Passport drive requires much more power from the USB to spin up, so, if you want to run it through the USB hub at the very least you will need to replace the USB hub with a powered one.
As for a driver, you don't need one to use the passport on XP that's why you can't find one but the Passport does require a dedicated port(2 for Amperage on some systems) or will need to be plugged into a powered hub or it simply won't get enough juice to fire up. That is the reason it won't show up.
In short, buy a powered hub, or plug it in direct. Nothing else is likely to work.
Hope this helps figure it out
Chris
May 07, 2009 | Western Digital Passport 320GB External...
Western Digital removable HD devise not found
For Western Digital Passport make sure you use the prigina;l USB cable or a replacement. They are not all the same. WD uses a propriatary cable with an extra power line I believe.
Apr 12, 2009 | Western Digital Passport WDXML800UE...
Problem accessing WD Passport Elite drive
The solution to this is associated with the power supplied by your laptop to the drive. It seems the passport drive needs about 1000mA of current which will be supplied by two USB ports on a laptop. It should be fine with a desktop USB port though is what I was told.
Feb 24, 2009 | Western Digital Passport WDXML800UE...
WD Passport 160 won't open
Before deciding if you have to check your computer or the disk, you might want to try this pasport on another laptop. If the same problem occurs, change the USB cable with a new (short) one and see if the problem is still there. If it is, then the drive is fried. You may want to take the disk out of the passport, hook it onto a desktop system using the sata bus of the drive and try recover programs like recuva or similar to retrieve the data.
May 11, 2017 | Western Digital Passport 160GB External...
320GB WD passport essential works with XP os but not with vista
both of my vista machines worked perfectly... i am not using the software that came on the drive. as a mass storage device it works perfectly.
Jan 29, 2009 | Western Digital Passport WDXML800UE...
WD Passport Elite 320 - won't install autobackup launcher
I just spoke to WD support...here is how to solve your problem:( I had the same problem and it works great now)
1. Connect your WD ext. drive.
2. Click open Computer.
3. Double click open the WD blue icon.
4. Double click open WD_Windows Tools.
5. Double click open WD drive manager.
6. Double click open the Setup icon for Vista 64 (the other icon
is for x86 windows)
run the setup and it will take care of your problem. enjoy!
Dec 01, 2008 | Western Digital Passport WDXML800UE...
The problems is this: at this point, Western Digital is not supporting Vista 64-bit with any of their related software. Granted, some things will still work while using the 32-bit version, but some won't, and the backup software is a prime example of the latter.
You might try downloading the latest version of the software from here:
http://support.wdc.com/product/download.asp?groupid=204&lang=en
Chances are, it will still barf, but it can't hurt to try it out. An alternative is to use another backup application; the one included with Vista ought to work. I wish I had better news, and believe me, as a user of both XP 64 and Vista 64, I feel your pain.
Cheers
Nick
Dec 01, 2008 | Western Digital External USB 2.0 80 GB...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
1,164 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
