Question about Topaz Systems (z-t-lbk462-hsb-r)
My network has a problem with monochrome .bmp files. Can I save my signature as a 24 Bit color .bmp file?
After capturing a signature, my system has a problem with the monochrome .bmp image displaying. I do not have any problems with color 24 Bit images. Can the Signature Pad be configured to save the signature image as a 24 Bit color .bmp file?
  • deminij May 10, 2010
    My best advice is to contact Datacard for a solution. You can set a line color other than Black. There may be a dependency on having capture software for this product. To contact Datacard call
    800.328.3996 you will need to provide your model and serial number to the customer care representative.
2 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: We setup the Topaz Siglite
So you are trying to decrypt the signature? Is the encrypted signature successfully sent to your web server? Please let me know a bit more and I can definitely help.
Posted on Sep 09, 2010
Can i use a picture saved in a file for my wallpaper
It needs to exported from the PDF as a image file like jpg, bmp, png... but to export it you may need Adobe Acrobat not just the reader. PDF files tend to locked. You could also capture the picture from the doc with print screen, but you will loose the original resolution.
Once you have the file exported, just open with Windows Picture viewer and set as backbround.
Jan 03, 2013 | Dell Latitude E6410 Notebook PC - Intel...
Tip
How to create stock DVD menus for Dimadsoft DVDRemake Pro
There are already 4 types pre-loaded Pool 2 is for PAL (720 x 576) with 2,3 and 4 merged titles and Pool 4 is for NTSC (720 x 480) however if you want to create your own the simplest way is to use Adobe Photoshop or CorelDraw and Muxman to create a dummy title and then import this into the stock menu.
All you need to do is located the correct titleset (this is normally the last one on a DVD merger) and right click it and select replace with still from the menu
The best way to create your own is to export an existing frame as a BMP to get the location buttons for you custom title and then use this as a starting point then create your own BMP and then use Muxman to create the VOB that you can then import into DVDRMKP to use for your new merger menu
NOTE:>> Muxman requires the use of 24 bit Bitmaps ONLY, if select the Photoshop 32 bit default this will give you an empty VOB but will not cause an error in Muxman v0.15R so make sure that when you save the file in Photoshop this has been pre-selected with the 24 bit mode.
If you are using the latest FREE version of Muxman v0.16.6 from the 14th October 2005 then you have the option of FORCING the aspect ratio and the resolution for either PAL or NTSC and 4:3 or letterbox 16:9 if you forget to use a 24 bit BMP the resulting VOB will look like this, caught me out a few times I must say..
Anyway point well and truly put I think so if you download version 0.16.6 and FORCE the video you can create not only the VOB file but also the corresponding IFO and BUP (VOB backup) for the BMP that you have created.
Click on START and then use this resulting VOB file to LOAD into DVDRMKP this will add yours to the stock list for use. It will work first time as you used the existing BMP as a template the buttons will already be in the correct place.
Also check out my CDR-Zone Tips wrt removal of commentaries with DVDRMKP from a few years ago
http://www.cdr-zone.com/forum/search.php?search_author=Spideray
Hidden within one of the CDR-Zone forums is this great tutorial by blackstar from 2009 no need to rewrite it here so goto the link below
http://backstar.com/blog/2009/09/22/create-new-menu-for-existing-dvd
This tutorial uses the following FREEWARE Tools and a drawing package for creating BMP's you could use MS paint however I suggest either Coraldraw, Paintshop Pro OR the ever popular Adobe Photoshop CS2
on May 27, 2010 | Televison & Video
Tip
Garmin POI, GPI, GPX, GDB and CSV and how not to be confused
GPX or CSV file can be converted to the proprietary Garmin format GPI format (Garmin Points of Interest) format using the Garmin POI loader v2.54 OR use the one bundled with the Garmin Map Source v6.15.11 at the time of posting if there is also a BMP file of the same filename then this will be added to the Waypoints Symbol.
If you put all your POI that you want to be added to the Garmin POI then place all them in the same folder prior to starting the POI Loader and they will be placed into sub-menus otherwise it will select the single file entries only.
However the Garmin Mapsource can't open this GPI format it is specifically for the SATNAV Device only open GDB, MPS, GPX and LOC files can be opened as standard. There are two ways that I know of that will convert this GPI back into CSV or the POI format if required you might like to open the POI content in the Map Source program.
First this can be done using GPI2GPS it does however cost 15 EUROs or its older brother GPSConvertor for an extra 20 EUROs will convert to all formats for all makes of device including Tom-Tom, Garmin and many others.
Secondly you can convert POI file in CSV format directly to GPX (exchange format) using the excellent GPXtoPOI Convertor v1.1.8 then import directly into the Map Source if you also want to use BMP that has been downloaded in Map Source you can replace the 8 default custom waypoint symbols located on your computer with your own or from the Tescos.ZIP file in this example that contains the CSV and BMP.
You can open these symbols with a graphic editor and use them as templates for creating your own symbols.You can add up to 64 custom waypoint symbols. These symbols must be in .bmp format and must be named numerically from "000.bmp" to "063.bmp." Custom waypoint symbols can be 16 x 16 pixels (small) or 24 x 24 pixels (large) and up to 32-bit color
Also check out my other POI tip HERE for help on how to create your own BMP's for use with your Garmin using Adobe Photoshop
It will also convert any GPX format into CSV format for use with the POI loader using the other button on the menu maybe this program would be best called GPXtoCSV instead to avoid confusion
And this one I saved for last If you want to transfer images from the Garmin use xImage and have your Garmi SATNAV connected.
For a full list of all POI sources then visit the Gamin POI Source another great website full of loads of useful tools is www.freegeographytools.com
If you are unable to use xImage it means that you unit is not compatible for example the Nuvi 250 will not be found and you may see this window
on Apr 18, 2010 | Garmin nuvi 250W GPS Receiver
Internet photos download as bitmaps instead of jpg's
First open Microsoft Paint by going to Start, All Programs, Accessories and then Paint
Now open the BMP file in Paint. Now all you have to do to save the file in JPG format is to simple do a Save As. Change the File Type drop down menu to JPG and click Save
Jun 11, 2010 | Compaq Presario 5000 PC Desktop
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have just tried to put a background on my R4 card, and i have pasted it onto the _SYSTEM_ folder, which i was told to do, and now there is no background. Please tell me what I should do. Thanks.
In the _SYSTEM_ folder you must have a "Themes" folder to put the skin files, into thet folder you can put many "theme#number" folders with different skins (i.e: theme13)
Into these theme# folder you put 4 image files forming the skin theme, with exactly the same names:
These images must be .BMP 8-BIT / 24-BIT sized 256x192 píxels.
Jun 20, 2009 | Nintendo DS Lite Console
How to run Malaware bytes
Hi!
You can use MS Paint application that is preinstalled in your system(if using windows). Or Microsoft office picture manager. Open a file in anyone of them and then click on "Save as..." in file menu. And, when a window opens up then select save as type and from there select bmp or jpg,etc
Thanks
Rylee
Feb 03, 2009 | Microsoft Windows XP Home Edition
Hi uplate
c:\windows\system32
open up "oemlogo.bmp" using paintbrush and save again as oemlogo.bmp making sure that it is going to be saved in the same place ie c:\windows\system32
once done either edit the oemlogo.bmp file or create a new image file, making sure that your new image file is the same pixle size as the origional oemlogo.bmp file.
my current oemlogo.bmp file is quite small, but experement to see what is best.
I initially found out how to do this from the following link. not all systems have this oemlogo.bmp file but you should be able to create one and save it in the system32 folder without issue.
http://www.windows-help-central.com/xp-system-properties-logo.html
Nov 07, 2008 | Microsoft Windows XP Professional
Can i capture my monitor screen tomy dvd writer
Do you mean still pictures , or moving pictures ?
for still images of the desktop , use the print screen key
and open paint and paste the image there , save it to a folder
to be burned to your DVD player as a BMP or JPEG
Save as Both BMP and a JPEG so that you'll gain compatability.
If this is about recording everything that happens on your monitor as a DVD file
That can be done by using software designed to do that.
FixYa!
Az.
Sep 16, 2008 | Computers & Internet
How do you change the packard bell splash screen @ the bootup process. can you edit your own pic
i dont think that you can edit you own pics it depens on what os you are running . is the splash screen your screen saver or what more info on the spash screen
Aug 18, 2008 | Packard Bell Computers & Internet
Topaz Systems (z-t-lbk462-hsb-r) Logo
62 people viewed this question
Top Topaz Systems Computers & Internet Experts
David Payne
David Payne
Are you a Topaz Systems Computer and Internet Expert? Answer questions, earn points and help others
