Question about Canon PowerShot S2 IS Digital Camera
Insufficient power to start, even with new batteries?
New batteries = 6Volts. Label on bottom of camera says 7.4Volts. Is it a design fault!?
  • siqingwei Sep 29, 2008
    I had the camera for a little over 2 years.
    The problem started about 6-9 months ago -- fresh battery (rechargeable) -- and the camera says "please replace battery"
    This happens occasionally back then -- I can resolve by replace load the same battery.
    As time goes by, this problem gets worse. Sometimes, nothing I do helps.
    The camera stays as a brick.
    what gives?
  • Anonymous Oct 02, 2008
    battery dies down after 20-30 shots.. I use EVF, still no improvement. I use Eneloops thinking its charge decay.. doesnt help.
My Dad (in-law) has one of these cameras and has tried several re-chargeable batteries.
Some of the less powerfull ones wouldn't even start the camera, others just didn't last.
He has now resolved to only using Duracell, as they are the only ones which give enough power and he always carries spares.
hope the helps !
OBC
Posted on Sep 17, 2008
I lost my charger for my digital camcorder
If you really can't find the one for your Camcorder, go and look for a Universal charger that comes with all sorts of plugs which one will fit your camcorder. When you get this Universal charger check the voltage on it. Usually the universal charger comes with many settings. Buy one with the settings that correspond to your camcorder. But one word of advice though, you must be careful when you use this kind of charger. Suppose your camera needs 8Volts for power (this is written on the label at the bottom of your camera) you be cautious then use the next lower level if it is say 6Volts. If your Camera powers on with this then keep it that way. the reason for my saying this is that sometimes the Universal Caharger is unreliable so you might get too much voltage from what is written on the Charger. Good Luck.
Oct 16, 2011 | Mustek DV526L Camcorder
When i start my camera it turns the light green to red and shuts off immeditaly
Green light indicates good battery strength. Red light indicates that your camera has an insufficient or low battery power level and will be automatically powered off. . To continue using the camera, please change your batteries to new ones.
Please note that:
  1. If you don’t intend to use your camera for an extended period of time, please remove the batteries to avoid battery leakage and corrosion.
  2. Do not mix old and new batteries.
  3. Alkaline batteries are generally recommended.
Feb 13, 2010 | Vivitar ViviCam 5355 Digital Camera
I just charged my camera's batteries and an error
Your camera is telling you that the batteries have insufficient power. First thing to check is that the battery contacts on both the batteries and inside the camera are bright, clean and free of grease or oil.
Assuming that you're using the original NiMH rechargeable batteries which came with the camera, then you almost certainly need to replace them with new ones as they cannot be reused indefinitely.
To test whether the problem is with your rechargeables or with your camera is very easy. Just buy a set good quality, non rechargeable, alkaline (e.g. Duracell) AA batteries. If the problem disappears then you know that you need to buy new rechargeable NiMH batteries next time.
There is also a small possibility that you have a faulty recharger but it's unlikely. The only way to test it without special tools is to try getting your NiMH batteries charged in a borrowed recharger. If the batteries get fully charged then the error message on your camera will vanish and you'll need to buy a new recharger. Just make sure that the charger is designed for NiMH though or you will damage your batteries and possibly the charger.
Jan 15, 2010 | Canon PowerShot A560 Digital Camera
I have Canon power shot S2 IS digital camera.I bought it around 2 years back.Now my camera is showing the sign of "change the batteries" even though the batteries are fully charged and the lens does not...
i suggest replacing a fresh battery will most likely solve your prob, overtime rechargeable battery can drain easily, try changing with a new battery and see if it does work well, there might be insufficient current, thats why it tends to drop of voltage easily upon using,
there is a specified lifetime for rechargeable battery, depends on your usage and charging method, theymaybe fully charged but sometimes wont give you enough power to drive
cheers
Nov 26, 2008 | Canon PowerShot A540 Digital Camera
Battery exhausted warning and eats new duracell without even starting!!
Actually I have this camera and one that didn't stay on without fresh batteries every few minutes was given to me to tinker with. It is a software problem and if you are patient and follow the directions exactly...a simple firmware upgrade should resolve this issue for you.
Go to: http://www.general-imaging.com/us/firmware.html
Locate the blue box on the left that says QUICK LINKS and then click on FIRMWARE UPGRADES and locate your camera model. I hope this is helpful.
Oct 15, 2008 | GE A730 Digital Camera
Camera wont turn on even with new batteries
In order to narrow down the issue, I suggest you the following steps. 1) First of all we have to power drain the Camera. Take out the battries and unplug adaptor, now hold the power on putton ( Click Button) for a minute this will clear the static power on Camera. If this doesn't fix the issue, Than.... 2) As cam is working fine with Ac adaport and batterys are not working you have to check the cam with the new battries. If you store battries for a long time with out using them, they may result in battery drain. If this doesn't work. 3) Then it need a Physical check, where we can track if Power suply from battries are reaching till its destination or not. This is the way to narrow down the issue. Thanks you.
Apr 08, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
S40 Battery problem
Alkaline batteries are not capable of outputting the level of power required for your camera to operate. Your daughter's camera may have lower requirements and be able to function properly using alkaline batteries. Your standard alkaline battery outputs about 700 milliamps of power when they are brand new. A rechargeable NiMH battery can range from 1200 to 2700 or even 3200 milliamps max power output depending on the quality of the battery. Most compact digital cameras that accept AA style batteries are designed for these high-output rechargeables and will not function for very long even on fresh Alkaline batteries. David Millier Advance Camera Repair
Mar 21, 2007 | Pentax Optio S50 Digital Camera
Rechargeable Battery won't charge
I think this is a general Fuji design fault in the camera circuitry. I have an older F455 which has exactly the same problem and I did the same - bought new batteries only to discover that didn't help. The only solution is to spend even more money for a stand alone battery charger.
Sep 07, 2006 | Fuji FinePix A340 Digital Camera
Even when I immediately switch power source (AC adapter or External Battery Pack) right after the low-battery icon started to blink, the camera operation is still locked.
In cases where the blinking low-battery icon appears indicating insufficient power, wait approximately 8 seconds until the LCD monitor display and the EVF become blank. Then switch to another power source or replace with fresh batteries.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
