Question about HP LaserJet 4000tn Printer
Papaer Jam I have a paper jam in the front roller, and I can not get to the paper by normal means, I need to be able to remove some of the system to get to it,
  • adi May 11, 2010
    it sounds like the paper pickup rollers need to be replaced, I would also replace the 4 half rollers that are inside the printer just above the tray. you can see them when you take the tray out.
    thanks
  • 526 Answers
Its not a simple process, but here are the basics.
1. remove the upper cover, 4 screws and the part that releases the toner is connected to the cover.
2. remove all side covers.
3. remove the manual tray
4. remove the tray 1 upper assembly, 2 long screws the go straight down, one on left side near front, one on right side, you will see it when you look straight down from the top.
5. remove about 5-6 big tapping screws, and unplug cable from left side and 1 from right side.
you should be able to see the jammed paper.
this is not that easy, so if you dont feel extremely comfortable, dont do it.
thanks
Posted on Aug 17, 2009
HAVE PAPER JAM CANT GET PAPAER OUT OF PRINTER
Hi
Yes, paper don't getting out of printer as is jam. If this is happening first you should check is how you storing your paper. Paper is likely to easy cumulating humidity from the air and need to by store in warm and dry place all the time. If you use incorrect stored paper that will sticking to the rolls or rolls will slide on paper which mean "paper jam".
Aug 17, 2015 | Office Equipment & Supplies
Hp laserjet m3035 mfp does not take up the paper squeaks and reports paper jam - no papaer is jammed
The most common cause of this type of Phantom paper jam is worn pickup rollers and separation pads in the paper trays. When these rollers get worn the gripping surface can not grab the paper correctly so no paper is fed into the printer and the printer gives the paper jam error. The rollers are very easy to replace, it takes about 20 minutes total. Here is a link to more information about the roller maint kit:
www.ccl-la.com/catalog/product_info.php?products_id=172
Mar 18, 2013 | HP LaserJet M3035 MFP Printer
Printer will not print, says that there is a paper jam but there is no paper in the print, and when we add paper the printer won't take it and the power light is blinking
you need to remove the black plastic on the back wipe the rollers that feed the paper put it back together plug it back in switch on and it should work some times u get a small corner of paper stuck so it tells the machine that u have a papaer jam
May 25, 2011 | Lexmark X1270 All-In-One InkJet Printer
Symbol lit up but don't know what symbol means, I don't have manuel - begins with 2 dots :
The symbol with the 2 dots and what looks like a jagged line is the paper jam indicator. Open the paper tray and or front and back access doors to find and remove the paper jam. I the light still does not clear try turning the printer off then on to reset the jam indication.
Aug 20, 2010 | Lexmark E260 Laser Printer
Paper jam
First I would request you to provide the name and the model of the printer which would helps us to provide you more specific troubleshooting steps for your type of printer. I am providing you some of the trouble shooting stpes which should be ideally done in cases like papaer jam:
* Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
* Turn off the printer.
* Remove any paper trays. Inspect them for wrinkled or damaged paper.
* Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
* If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
* If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly . The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
* If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
* Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
* If the printer paper jam message still appears, then there is still some paper in the printer.
Hope this would resolve the issue.
Thank you for contacting Fixya.
Jul 10, 2009 | Office Equipment & Supplies
Paper jam
It jams due to the rollers. Please change the rollers and it should be good. also pay attention to the way the paper is being seated in the drawer.
Jun 29, 2009 | Samsung CLX 3160fn All-In-One Printer
False paper jam
Try cleaning the feed rollers with some alcohol on a lint free cloth. You may have some debris on the rollers.
Jan 31, 2009 | Lexmark P4350 All-In-One InkJet Printer
Panasonic kx-fp 342 papaer jam
paper jam or missfeed always due tothe following:-
1-malefunction of paper feeding system due to broken gears belt chain please check smoth mechnical movement and apply light grease in gears and change any broken part.
2-something is blocking the paper path (staplers-pins)droped inside.
3-malefunction of paper detection micoswitch please confirm free operation for the lever in mechnical one and clean of dust and dirt from optical one,
Mar 06, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
Deskjet f340
You have a paper jam. get a torch and thoroughly check doen behind unit where paper goes after removing all paper. Oopen cover, let carriage move, once settled, check everywhere her too, all around, rollers, near carriage, teeth, sides, etc, and remember it can be the tiniest slip easily missed. Good luck.
Mar 06, 2007 | HP Deskjet F340 All-In-One Printer
HP LaserJet 4000tn Printer Logo
42 people viewed this question
Ben Johnson
