Question about Brother LS-2125 Mechanical Sewing Machine
My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
My Disney Brother SE-27OD Embroidery Sewing Machine is having a problem. The top thread is not picking up the bottom (bobbin) thread. A tangle of thread occurs. I have gotten a new bobbin case but replacing the case has not solved the problem. Any ideas?
  • Anonymous Mar 29, 2014
    is there a singer prewound bobbin i can use
Can you buy embroider memory cards with out down loading on your PC?
Posted on Jan 15, 2009
  • 21 Answers
Make sure that your needle is put in the correct way, there is a groove in the front of the needle, check with your finger nail, this is usually to be facing you, and make sure the thread is going through the tension holder correctly do not have the foot down when you are threading the machine,as this stops the thread from going through the needle tension holder.
Posted on Sep 21, 2008
The needle threader on my embroidery machine is no longer working.
There's a possibility of it being related. I would need more information though.
Jan 26, 2014 | Brother SE-270D Computerized Sewing...
Hi,i have a disney sewing and embroidery amchine.It won't loop th it was threads together.Local repair man said it was o/ut of time.CAN YOU HELP/
If the timing is off is needs an authorized repairman to fix it with metric tools. Not a repair that can be done at home. Usually costs between $50-150 depending on your area.
Aug 14, 2010 | Brother SE-270D Computerized Sewing...
Stitching trouble
Here is a trouble shooting chart - http://www.emblibrary.com/EL/elprojects/SimpleProduct_ELP.aspx?CS_ProductID=PR1238&CS_Catalog=Elprojects
I would start with cleaning (see maintenance section of the user's manual).
This has to be done more often with sewing/embroidery machines that have a drop-in bobbin.
Be sure to use bobbin thread for machine embroidery.
Always thread the machine with the presser foot up. This will insure the thread is seating into the tension control.
Apr 30, 2010 | Brother Disney PE-180D Computerized Sewing...
I have a Disney Brother SE-27OD Embroidery Sewing Machine When I am doing the embroidery the needle comes out I put it in as tight as possible but it keeps happening from time to time.
Make sure you have the flat part of the needle to the back when putting it in and that it's (preferably) a Schmetz embroidery needle with the red band either 75 or 90 or a Schmetz universal 80. Make sure when you install it you can see the top of the needle in the needle slot and all the way up so it's hitting the post before you turn the screw tight. Check the screw each time you sew to make sure it hasn't shaken loose from embroidering.
Dec 13, 2009 | Brother SE-270D Computerized Sewing...
I'm new to embroidering. I have BrotherSE-270 Disney. I have read through the manuel several times and am confused about the bobbin thread. Do I use tread specficaly for embrodering or will regular thread...
Your machine probably came with brother embroidery bobbin thread (one spool, white)...I used it until it was gone and did buy more embroidery bobbin thread at a regular superstore (it wasn't brother brand though)...however, I have since used regular thread and not had problems. HOWEVER, be sure it is good, quality thread - none of that $.50/spool stuff. That knots up and simply doesn't look good if it does work. Good luck!
Jul 08, 2009 | Brother SE-270D Computerized Sewing...
Thread wad on undersurface
machine not threaded properly? wadding thread underside means upper thread does not have tension.
Jun 30, 2009 | Brother SE-270D Computerized Sewing...
Problem with Brother Quattro
This is an Embroidery machine. Use a thicker thread if only sewing. If doing embroidery, check your hoop for proper size, and make it tight holding the material.
Jan 03, 2018 | Brother SE-270D Computerized Sewing...
How to use automatic threader on the pe180d embroidery machine
make sure needle is in the highest position before you thread
mary h
Jan 06, 2009 | Brother Disney PE-180D Computerized Sewing...
Brother LS-2125 Mechanical Sewing Machine Logo
335 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
