Question about Boston Acoustics Recepter Clock Radio
Battery compartment cover doesn't close properly
This results in the battery not being pushed into the compartment far enough to engage, which means no battery backup. Pushing on the compartment cover engages the battery, but who's got the time to sit there pushing that thing in all the time in case of power failure?
I had the same problem with my wife's vibrator. I was taking business trips almost every week for 6 months. She was going through those D batteries so much that we were buying them in bulk from Costco. Anyway - from constantly changing the batteries we weakened the spring-lock mechanism on the screw-top. Being her favorite toy, I so didnt want to disappoint her. It had such sentimental value as we purchased this on our 1st date at the local flea market as a gag. It appeared almost-new so what the heck. Anyway - try rubbing the connectors with a little tin foil from time to time to keep them clean. Every once in awhile some baby oil leaks into the chamber and causes it to short-out. Any suggestions on that?
Posted on Mar 13, 2007
    Champion:
  • 277 Answers
Hi first of all why isnt the cover closing? check for correct size of battary (its on the unit, maybe inside the compartment : A, AA ,D.....) check inside the compartment if there is anything that disturbes if its just the little tongue of a lock that is broken then you can take a strong tape and just shove the battries in and put the tape on good luck
Posted on Mar 16, 2006
Drivers door will not latch closed
It appears that the door is not closing far enough for the latch to move to the second position in it's movement. ie on not closing the door properly you will see that it is latched but not closed . Push it harder and it closes properly. Lubricate the latch mechanism and you may have to adjust the catch position to allow the lock to go to the fully locked position POssible rubbers to cold and stiff to allow the door to close easily
Feb 03, 2013 | 1997 Ford Escort
Tip
What to do when the "replace system battery" message displays on a Partner ACS...
The Partner ACS system uses 2 AAA batteries to retain programming from 45 to180 days, in the event of a power outage. When these batteries fail, a system warning (replace sys bat w/ power on) will display on the screen of extensions 10 and 11. Replacing the system batteries doesn't require a service technician and is fairly simple to do providing you know the proper steps.
With new batteries in hand, go to the phone system cabinet and find the system processor. The system processor will be marked on the top third of the card with a label marked "Partner ACS processor".
On the bottom of the processor module,below the extension jacks, there is a battery compartment. With the power on, Push in slightly on the battery compartment and slide the black locking latch up to cover the"+" icon. Remove the battery assembly by pulling the tab at the bottom of the compartment cover.Place the batteries into the metal battery clips fully. Make sure the polarity of the batteries is correct by looking inside the metal battery clips for the "+" and "-" icons cut into the metal of the battery clip. With the locking latch in the unlocked (up) position slide the battery assembly back into the processor card far enough that the edges of the assembly slip behind the plastic housing of the processor card.Slide the locking latch down to secure the battery compartment. The message on your screen will disappear if the batteries are inserted correctly.
on Jun 17, 2010 | Lands Phones
Interior lights come on, draining battery
You should check the various door switches and any manual cab light switch. A little physical movement on those switches should be able to identify the problem area. With the door open you should see the switch that gets pushed in when the door is closed. Push it in with your finger and see if it reacts properly. sometimes there's a little tab on the door itself that would be the contact point with that switch and if it comes off or is damaged, the switch doesn't get pushed in far enough.
Aug 27, 2012 | 2000 Mercury Grand Marquis
Hi, I had a start problem with my celica. tried to turn the car over and a constant clicking sound was made, however all lights were on and the radio was working.. thought possible starter problem,...
The problem is that your battery is extremely low. The repeated clicking sound is your starter relay trying to engage, then releasing again when the starter takes the remaining voltage available to try to turn. When the relay disengages, the starter can no longer take any voltage at all, so the relay again engages and the process starts over. This results in "CLICK, CLICK, CLICK, CLICK...." There simply is not enough power available to operate both the relay and the starter.
Your alarm system doesn't have enough voltage to function properly. It "thinks" that someone is trying to steal your car or is messing with your battery cables. It doesn't know the difference between low voltage from a dead battery and low voltage from somebody disconnecting wires. It is simply responding to the low voltage condition as it is designed to do. Fix the voltage problem and you will fix your security system. No need to reset anything.
Jump-start the car or replace the battery and get your charging system checked to make sure everything is functioning properly. It is possible that the battery is good but you have a bad alternator and the battery is low because it is not being charged.
Aug 17, 2011 | Toyota Celica Cars & Trucks
I had to replace the horn cancelling switch on my 1986 Chevy truck. No tilt. I got the wheel and locking ring off, replaced the part and now I can't get the lock ring back on all the way. I've got...
Hi, been there, done that--the likely cause is the bearing slipping out the other end of the column. Go in the engine compartment and push it back in and have someone hold it in while you compress the plate spring.
Aug 17, 2011 | 1986 Chevrolet Chevy
Please advise how to close the battery cover
Hello and Welcomethe Canon A560's bottom panel is reasonably flat, with a sliding door to access the battery compartment and a threaded plastic tripod mount off in the opposite corner. The battery door and tripod mount are far enough away from each other to permit quick battery changes while working with most tripods To close the battery cover first Hold it and make it Flat and then by the tip of Your thumb Press it in inner side To demonstrate it the image is given below: angel_bird_0.jpg
Further assistance i am here to help
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Mar 09, 2011 | Canon PowerShot A560 Digital Camera
John Deere 318 blades won't engage once it gets hot.
Check the clutch gap in the front of the machine (the one that engages the belt) by tightening or loosening three lock nuts around clutch. Tightening decreases gap/ loosening increases gap. Note: do not tighten too far as it will result in clutch drag or lockup! Stop when its just starting to touch then back off slightly. Also without a proper charge on the battery the magnetic power for the clutch is altered and not strong enough to engage clutch when hot. Find out why battery light is on.
May 01, 2010 | John Deere 420,1020,2010,2020,2510,2520...
How do I add or remove a memory card
Open up battery compartment, slide in sd card until it clicks in place, or just push far in as it will go. Close battery cover and you are ready to go.
Nov 30, 2009 | Kodak EasyShare M1033 Digital Camera
I have olympus e300 evolt and the read out says card cover open when it is closed any ideas?
my Cannon has to be well clipped in ... scares me doing it but they can be a little tight and of course must be the right way around ... most are lug prevented from misplacement ... then of course I cannot get it out ! later on, just a guess . Mike could be corroded, grubby electrical connect as it is shut ?
Jun 13, 2009 | Olympus EVOLT E-300 (Double Lens Kit)...
Remote unit slides open but cant find battery cover-model AR-DL10
When sliding the bottom part of the remote down, you have to lift it slightly (I did this with a letter opener - very carefully) to pry the door up from two stops that normally prevent the dorr from sliding down too far. If you look carefully, you can see what I mean.
Feb 04, 2009 | Fujitsu 24C1 Air Conditioner
Boston Acoustics Recepter Clock Radio Logo
301 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
donny ardalando
donny ardalando
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
