Question about Philips GoGear HDD075/17 MP3 Player
I cannot get the device manager to recognize the player
I have downloaded all the drivers but I can't get the device manager to recognize the player not can I get Windows Media Player to connect to my player.
Please any help is apperciated.
Thanks! i've transfered a lot of mp3's tracks but it wont play
  • 8,596 Answers
Make sure that the hold.lock is not engaged.
If not, then get the latest version of the installation software from Philips website.
Posted on Mar 07, 2009
My computer cant recognize my mp3.problem with code 28?
INSTALL THE DRIVER FOR YOUR MP3 PLAYER .THEN YOUR COMPUTER WILL RECOGNIZE IT
Code 28 The drivers for this device are not installed. (Code 28)Recommended resolution
Install the driver
You may be prompted to provide the path of the driver. Windows may have the driver built-in. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. Right-click My Computer, and then click Properties.
  2. Select the Hardware tab, and then click Device Manager.
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to install the driver.
Mar 06, 2010 | Sony NWZB135F MP3 Player
Sony NWZB135F not reconized by computer
Hi!
No drivers are required to connect the Walkman to a Computer. Please make sure that the USB ports to which the Walkman is being connected is properly functioning. Next, press and hold the Reset button on the Walkman for 30 seconds.
Then, connect the Walkman to the Computer and check if it's being recognized. If not then open Device Manager window then check if there is any exclamation mark visible under any category specifially under "portable devices" or "Disk drives" category. If there is any exclamation mark visible beside any devices under any category, please right click on it and click Uninstall. After uninstalling all the devices with exclamation mark, please restart the Computer. After restarting the Computer with the Walkman should be recognized by the Computer.
Please follow the steps given below to open device manager:
Please press the Windows logo on the Keyboard and then press the "R" key while holding down the Windows logo key to open the Run dialog box. Then, please type "devmgmt.msc" in the Run dialog box and click OK to open the Device Manager window.
Performing all the above steps should make the Walkman work with the Computer.
Aug 23, 2009 | Sony NWZB135F MP3 Player
Window media player is not recognizing my sansa m230
Refresh drivers - connect player to PC. Right-click My Computer & select Manage. Click Device Manager on left pane. Player will show on right pane as USB Mass Storage device or Portable Device.
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers: right-click the entry with the error & select Uninstall. On top menu, click Action then select Scan For Hardware Changes.
Feb 21, 2009 | SanDisk Sansa m230 MP3 Player
IRiver Music Manger not recognizing iRiver player when connected
First make sure you have the right drivers installed, you're hearing the "new device connected" sound when you plug it in, it's listed as recognized under device manager, and the only problem seems to be that iriver music manager isn't recognizing it.
If everything is working except for the music manager, then try holding down the "fast-forward" button at the same time that you connect the cable to the iriver. You probably want to keep iriver music manager loaded, to see if it's recognizing the player while you test this; try attaching/detaching the device several times, while you're holding down fast-forward and while you aren't, to see if that's enough to fix your problem.
I have no idea why it works when it does, it's an ugly kludge, but it seemed to fix the problem for me, and saved me from having to buy an entirely new flash mp3 player to replace this ancient one.
Jan 23, 2009 | iRiver iFP-795 MP3 Player
ok remove everything what has to do with your mp4. then re-install everything. if you have windows medialplayer 11 then its ok or you must upgrade it. then i think its ok
Apr 12, 2008 | Philips GOGEAR SA6045 MP3 Player
Ipod doesnt connect to my pc/i cant download
I had a very similar problem with a USB camcroder, drove me crazy! This sounds like a USB device4.gif not being recognized, this issue is rather uncommon with XP, it's not the player or device, unless the device is not working proplerly. 9 out of 10 times it's system device manager.
(Solution)
With the device plugged into the USB go to control panel and click on system and navigate to your device manager hardware>device manager, scroll down to Universal Serial Bus Controllers, there should be either an X or an exclamation mark indicating the device/driver is not loaded properly, right click on that line and chose uninstall driver, reboot then plug the device in, if it asks for a driver then put in the CD and let the driver install it. If this still does not work, then repeat the above but instead of choosing uninstall when you right click choose "update driver" and when it asks for a location to the driver, point it to the driver on the CD.
Hope this helps
Dec 28, 2007 | Apple iPod nano
System not recognizing mp3
I had a very similar problem with a USB camcroder, drove me crazy! This sounds like a USB device not being recognized, this issue is rather uncommon with XP, it's not the player or device, unless the device is not working proplerly. 9 out of 10 times it's system device manager.
(Solution)
Hope this helps
Dec 26, 2007 | Disney Mickey Digital Mix Sticks MP3...
Philips GoGear HDD075/17 MP3 Player Logo
70 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
