Question about Sharp Office Equipment & Supplies
MY SHARP AR 505 IS GIVING ME A F-239 CODE, I HAVE REPLACED THE DRUM,ROLLERS, DOORS, TRAYS, CLEANING BLADES JUST ABOUT EVERYTHING BUT IT STILL ISN'T WORKING PROPERLY
I have a Sharp AR 505 for sale if you are interested $100. You can contact me at 214-880-4800. Toni.
Posted on Sep 11, 2008
HOW DO I REST AR-M326 SHARP COPIER TO FACTORY SETTING?
lite print might mean the the LASER is blocked (Clean the glass that the LASER comes thru, also the Transfer and sep assy. roller (Sponge looking or the very thin wires across from the drum need to be cleaned or replace (DO NOT WET WITH ANYTHING THE SPONGE LOOKING ROLLER, Replace if dirty
Mar 27, 2015 | Sharp Office Equipment & Supplies
PRINTING A SHADOW
Replace the upper heat roller first, 99%, this will resolve your problem, after replacing the heat roller if the problem is not getting resolved you have to replace drum, developer cleaning blade and maincharger together because all are consumables and replacing it together will give you a betttter life span . Rate this after your problem get resolved
May 04, 2011 | Sharp AR-M205 Copier
Sharp AR 207 paper gets lifted out of tray but will not continue to feed into machine. Side feed works fine
try cleaning the paper feed rollers in (above) the tray. and the rollers on the right side (theres 3 gray rollers) If thats works you will need to replace the rollers soon.
Aug 28, 2010 | Sharp AR-207 Copier
Sharp AR 5320 printing a shadow copy
Shadow images may caused by several things :
1. Deformed rubber of the cleaning blade,
2. Drum aging,
3. Upper heater roller aging.
Jun 22, 2009 | Sharp Office Equipment & Supplies
On a sharp arm 257 can you a drum unit or just blade and drum
Did you mean drum frame unit ? This frame include all the spare parts of drum unit except drum and drum fixing plate. The code number is AR 310 DU ( DRUM FRAME UNIT ).
DRUM : AR 310 DR
CL. BLADE : AR 271 AK
DEVELOPER : AR 271 SD
Jun 03, 2009 | Sharp AR-M237 Copier
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
AR 200- paper pulls to the green bar and then stops- will not print or move from there and screen says to clear paper path. no paper moves beyond the same point.
This "green bar" (registration roller) could be a few things
  1. Registration sensor dirty or inoperable
  2. Feed tires dirty
  3. Registration rollers dirty
  4. Fuser gate broken
For item 1 the flag and sensor is located under the copier. if you only have one tray then this can be located and removed easily. if you have 2 trays then this get more difficult. Here are the steps for one tray
  1. Open and remove right side door
  2. Remove toner, developer, and drum unit
  3. Remove paper tray
  4. Turn copier on its right side
  5. (Top is away from table and bottom is towards table) Towards the bottom of the copier there is a guide that needs to be removed (2 screws)
  6. There is a cover where a couple of wires are going to needs to be removed (use caution)
  7. Once removed take can of air and blow out sensor
  8. Replace items as removed
For item 2 follow steps 1-4 and locate tires clean using warm soapy water on a lint free cloth or mechanics towel
For item 3 open and remove right side door and clean grey rollers located under green cylinder which is your drum (USE caution not to touch or damage)
If the first 3 steps do not help then you should call your local Sharp dealer for repairs.
Mar 17, 2009 | Sharp Office Equipment & Supplies
Drum replacement
simple - service code 24-7 will rest drum, sevice 42-1 will rest deveolper service code 20-1 will reset serice indicators you can get a service manuel at persision roller in phx arizona and all parts
Feb 27, 2009 | Sharp AR-5316 Advanced Digital Imager...
When I photostat, items repeat one page
Replace the drum and cleaning blade,also check that the fusing roller is clean.
Nov 10, 2008 | Sharp AR-5320 Black and White Copier
230 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
