Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony kv-36hs510 36
My sony tv has no picture there is a continually flashing of 7 times any idea what the problem is? and how much the cost is to fix?
  • 6 more comments
  • harleyfordd Sep 10, 2008
    Sony kv-36hs510 blinks 6 times tv turns on but no pictures suggestions or problem.
    Regards David
  • Anonymous Dec 09, 2008
  • belzinga Dec 26, 2008
    Oh my gosh.  I just had this happen yesterday (Dec. 24, 2008) while I was turning off a DVD (thought there was a connection to that).  I have a Sony Wega Trinitron KV27FS13 and my front panel "Standby/Timer" light flashes 4 times in a row.  I have tried the manual idea (unplug and replug) but nothing works.  My TV sounds like it's turning on but immediately turns itself off.  The light are flashing consistently at 4 flashes per interval.  I also emailed SONY tech help and they said it needs service call.  But if only a few years old, how could this happen?  If anyone finds anything, let me know.  This is frustrating!
  • 1patterso195 Jan 01, 2009
    My TV too is flashing several times. But my TV is an older Sony Trinintron. Maybe 5 or 6 years old. I just figured the picture tube was about to go, but I really don't know.
  • Anonymous Feb 13, 2009
    same spny tv, same 7 flashes, no picture.
  • dwats91 Feb 22, 2009
    set would not turn on - not with remote, and not manually...standby light flashed 7 times..finally came on, but is stuck in initial setup mode and screen says to connect cable/antenna (which has always been connected). any ideas?
  • barnettwalke Apr 06, 2009
    No lights flashing on my WEGA 36 inch Sony but it goes black about once (for a second or so) and then goes back to working for another 10-15 seconds then repeats. Help Please?
  • mooseplane Apr 27, 2009
    04-27-2009 Mine has also gone into the 7 flash thingie. From what I read, what a pain. It's a big set. Guess I will make a few phone calls and see what happens. Mel
    Brigadier General:
  • 6,966 Answers
The blinking LEDs indicates that the built-in protection circuitry has detected a fault and in order to prevent further damages stops the unit from energizing/powering on. Often 7 blinks indicate probable area where to start diagnosis/checks. In your case, this would be:
  • "High Voltage Shutdown. The high voltage has exceeded 33K and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits."
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional or claim warranty repairs. Depending on the hardware faults, your location, prevailing service fees in your area, repair cost could be anywhere from 100 to 500 USD (wild guess).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 09, 2008
  • Louie  Role
    Louie Role Sep 10, 2008
    Six Blinks---No Horizontal (H STOP), no raster, goes to the blinking self diagnosis function immediately. On most versions, pls check C515 & 516 and the jungle IC, IC206.
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
Aug 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Have Sony KV-34HS420 with no picture or sound. Timer/Stand By light flashes 7 times with pause in between. What is the likely problem and cost to repair?
Hold hair dryer to back right side on high heat for a couple of seconds while you hit the power button several times. It only took 2 times for my set to power on. Good Luck!
Aug 12, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My Sony TV: FD Trinitron Wega - Mod. No. KV-34HS420 won't turn on. The red LED near the power button is flashing 7 times, then it pauses and flashes 7 times again. When I turn the power on it just makes...
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 11, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Nov 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony kv-34xbr8oo
Good day.
7 years is quite a young age for a tv. I think that your problem has to do with the loose contacts in the circuitry. You can resolder the loose contacts this might resolve the problem.
Response is highly appreciated.
chris
Mar 24, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
RE: Flashing "Standby" light
LED blinking Seven times. High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Jan 21, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Sony KV-24LS35U green light flashing 11 times
The Sony error codes go up to 7, so when the standby light flashes 11 times it usually means that one of the clock or data lines deep inside the set is shorted to ground. This is not fixable from the front or through the remote, so the set should be serviced by a qualified tech familiar with Sony sets.
Aug 06, 2007 | Sony KV-DR29M69 29" TV
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
538 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
