Question about Canon DR-1210C Scanner
Canon DR 1210 C Communication error
I installed the driver/software for the cannon DR 1210 C on my computer, with the scanner attached via usb and it was switched on, which I later read in the installation manual , that was a wrong way to do it. So I got the communication error onthe scanner screen.
Then I went ahaed and uninstalled the drivers and software from the contol panel and instllaed the software again followinng all the installation instructiuons that came with it, but I am still getting the communication error screen on the scanner screen instead of showing "Reading".
Is there any thing that I am missing , do I need to go into the registry somewhere to delete some enteries.
Thanks in advance.
Nausher.
  • tony77584 Feb 21, 2009
    i have same problem - the connectivity symbol on the scanner never goes off.
  • 490 Answers
After uninstallin you need to reboot the computer and install as per procedure. this should help.
S. Mohan
Posted on Mar 27, 2009
DR-9080c Isn't being detected via USB
Uninstall the device driver, restart the Comp and reinstall the software. If the scanner is not detected, try inserting any working device on the same USB port. if it detected, thee could be problem in the Scanner, if the new device is not detected, then it may be port problem.
S. Mohan, India
Feb 07, 2013 | Canon DR-9080C Path-Through Scanner
DR-6080 not recognised after reloading Windows 7 (32-bit) on laptop. Re-installed latest driver (says Win7 supported) successfully but still won't work, Anything?
Disconnect the scanner from the computer. Uninstall driver software, shut down and restart the Comp. Reinstall the driver. (http://software.canon-europe.com/software/0036991.asp?model= ). connect the scanner and the system will report USB device plugged in. This should work.
S. Mohan. Chennai, India
Dec 02, 2011 | Canon DR-6080 Path-Through Scanner
I have the canon dr-1210c scanner. Software is
check first to see if ur scanner is compatible with ur windows operating system if is the next thing i would suggest in uninstalling the software the reinstalling the software.
Jul 28, 2010 | Canon DR-1210C Scanner
Hi, I have brand new Canon MP140 3 in 1. I am getting the error message &cannot communicate with scanner. Cable may be disconnected or scanner may be turned off. Check status. scanner driver will be...
1. If you are connected correctly (via a USB cable), first be certain that the cable is snug on both sides (PC and Canon MP140).
2. If still a problem, remove the Canon MP140 icon from Printers and Faxes.
3. Then, disconnect the USB cable.
4. Restart your PC and log into Windows.
5. Connect the USB cable.
6. The PC should recognize the Canon MP130 and ask for a driver.
7. Install the driver.
If #6 does not happen, your USB cable could be faulty or may be a problem with USB port or your Canon. Move USB cable to a different USB port on the PC. Replace the USB cable. Try to install the Canon on a different PC to test.
Hope this helps.
Aug 11, 2009 | Panda ANTIVIRUS ED PLT 7.0 1YR 26-50...
Same problem Microsoft document scanner cannot see scanner
did you change o/s //some cases you need a different driver/check their home page(cannon)//oz
Aug 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I recently set up a new DELL optilplex 760. When I go to install my Canon DR-2080c I get an error stating "Device Not Found". I've uninstalled and reinstalled many times but still no luck. Can anyone help...
Have you installed device driver? It is just not enough if you install scanning software. Also trya different USB port o a different USB cable.
S. Mohan, India
Jun 04, 2009 | Canon DR 2080C Path-Through Scanner
Scanner not found
Have you installed ISIS/TWAIN Drivers? If not download item 4 from this link http://software.canon-europe.com/products/0010203.asp
If you are using Vista, you must install corresponding drivers.
S. Mohan, Chennai, India
Apr 12, 2009 | Canon DR-5010C Scanner
The cannon DR 2580-C resinstalled to new computer
Capture perfect is scannig software, it is not a driver. You can download driver from this site. http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11360
Install driver and use Captureperfect to scan.
Feb 21, 2009 | Canon DR-2580C Path-Through Scanner
772 people viewed this question
old marine
old marine
