I have a Gateway S-7700 series laptop. The problem I've had & seems to be getting worse is the synaptics touch pad mouse. The mouse pointer goes NUTS! & just jumps all over the place & when I'm typing the cursor will suddenly jump to another place on the page & while I'm a pretty fast typist I totally screws up my document, email or whatever I might be working on. Can you help me please?
    President:
  • 2,961 Answers
Go to my computer, right click>properties>hardware tab>device manager, then look down the list for mice and pointing devices, click the '+' sign and right click on your touchpad and select uninstall, do the same on the keyboard line and then restart the pc.
Both touchpad and keyboard will be reinstalled and then ready to use again as it should be back to normal
Posted on Sep 09, 2008
Gateway HDMI laptop T series charger output 19 vgets v.hotbut works . burser pointer starts jumping frm place to place on screen dificult to control ?
run it in battery to see if fixes cursor problem
also try a different mouse see if that makes the cursor move correctly
this way you see if its the mouse or power supply
might also a touch pad problem anything that controls the cursor
May 07, 2015 | Gateway Computers & Internet
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
I have a Compaq Presario f700, whenever I click on something it jumps to bottom of page. I click pg up, arrow key, side bar and it responds then goes to bottom again. It seems to be worse when I first turn...
sounds like your synaptic touch pad settings have been tampered with. make sure driver is installed the go into control panel and click on the synaptic touch pad and check the settings
May 24, 2011 | Computers & Internet
Ha a Toshiba Satellite a100 I can not turn off the touch pad (as I only want to use the mouse). Both touch pad and mouse are working. the laptop had to be reformatted recently and its since then All...
If your computer have a, Synaptics Touchpad you can try these steps:
1. Access the properties of the Synaptics Pointing Device by right-clicking on the system tray icon at the bottom right-hand corner of the screen. If you do not see the icon, open your Control Panel and select the "Performance and Maintenance" option. Click "System", then "Hardware", then "Device Manager" to view the devices on your computer. Open the "Mice and Other Pointing Devices" selection.
2. Click on the "Device Settings" tab of the "Mouse Properties" window. The "Device Settings" tab is at the top of the window and located farthest to the right
3. Highlight the Synaptics Touchpad from the list of available pointing devices. Click the "Disable" button underneath the list. Click "OK" on the pop-up menu to confirm your selection. Click "OK" on the Mouse Properties window to close the window. Your Synaptics Touchpad will now be disabled.
Make sure to connect a USB mouse to your laptop before disabling the touchpad so that you will still have control of your pointer.
Hope this help. Goodluck!
Mar 23, 2011 | Toshiba Satellite A40-S161 Notebook
Help. I want to disable the touch pad on my Gateway M6866 laptop. Whenever I am typing and get near the pad, the typing goes all over the screen. Any help will be appreciated.
Follow these steps to turn on or turn off the touchpad and optional pointing device.
  1. From the Start menu, click Control Panel.Note: If your Control Panel is in Category View, click Printers and Other Hardware.
  2. In Control Panel, click or double-click the Mouse icon.
  3. In the Mouse Properties dialog box, click the Device Settings tab.
  4. Click to select the device you want to turn on or turn off, and then click Enable or Disable.
Mar 13, 2011 | Gateway M-6866 Notebook
Mouse moves on its own
Your palm might be brushing on the touch pad while you are typing that is probably why the cursor jumps to a different location. as for disabling the touch pad I think that it is not possible unless you install a synaptics driver for your laptops touch pad.
Apr 01, 2009 | Gateway Laptop Keyboard for MX6930,...
Laptop t-series
Use external (USB) mouse; check/adjust mouse properties double-click speed. Open/clean or replace touchpad.
May 25, 2008 | Gateway Computers & Internet
Gateway notebook touchpad
Thank you mewms_14904. The problem was the F key. In my case it was F7 that enables and disables the glide pad of my notebook.By pressing fn key and then F7 solved my case.
Apr 16, 2008 | Gateway MT3705 Notebook
Touch pad is not working
I had a similar problem which I remedied by removing and cleaning the touchpad, there was some dirt which had collected around the edges of the pad underneath the case. The only drawback is that the majority of the laptop must be disassembled to get to the touchpad.
Sep 07, 2006 | Dell Inspiron 8200 Notebook
Open Questions:
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
