I found this on the Epson Web Site. If you find this information helpful, pls rate me.
You can download the Reference Guide with pictures and all.
http://files.support.epson.com/htmldocs/r220__/r220__rf/index.htm
Windows
You can check the amount of ink remaining in the ink cartridges using EPSON Status Monitor 3 or the progress meter. Refer to the sections below for details.
Access EPSON Status Monitor 3 in one of the following ways.
- Double-click the printer-shaped shortcut icon on your Windows taskbar. To add a shortcut icon to the taskbar, see the section below.
See Monitoring Preferences
- Open the printer software, click the Maintenance tab, then click the EPSON Status Monitor 3 button.
A graphic displays the remaining amount of ink.
If any of the ink cartridges installed in the printer is broken, incompatible with the printer model, or improperly installed, EPSON Status Monitor 3 will not display an accurate calculation for the amount of ink remaining in any of the ink cartridges. Be sure to replace or reinstall any ink cartridge indicated by EPSON Status Monitor 3.
Pls rate me. Thanks and Good Luck.....
