Error #1200 I have Lexmark X4270 and after replacing a 71 Black Cartridge I develope a problem Error #1200. I need to use the system but can`t get this resolved, please help! wolf.walsh@gmail.com
  • 1,029 Answers
Hardware Error: 1200
the printer is stalled.
1. Press Power to turn off
2. Unplug your printer from the wall outlet.
3 Check for paper jams.
4 Plug in your printer
2nd option Cartridge Error: 1200
The cartridge carrier is jammed.
1. Turn off you all-in-one
2. Unplug the all-in-one form the wall outlet.
3. Open the control panel.
4 Open the cartridge access door
5. Make sure the cartridges are snapped in place in the carrier.
6. Check for objects obstructing the carrier.
7. Plug in your printer
8. Press power to turn it back on. you can equally check this link for full and detailed description of the problem and solution http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&emeaframe=&docid=ENUS23485
Hope this resolves your issues.
Posted on Sep 09, 2008
I have error 1200 on my lexmark x4270 fax machine after installing new black cartridge.
The 1200 error code indicates that the cartridge carrier has stalled. It could be due to the new black cartridge installed in the printer. Make sure you are using the correct version of black cartridge for your model and it's properly inserted in the cartridge carrier.
To remedy the problem, try to remove the black cartridge from the carrier > close the cover > unplug and re-plug the printer into the power source to reset it > when the printer turns on, re-insert the new black cartridge > check for any errors. If problem continues, try to insert a different known working black cartridge to determine if the new one is faulty.
For further troubleshooting, you may also refer to this article found in the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
Jul 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
Used x4270 .no cd to download. list of printers does not inclued 4270. having problems with error 1200. took out old cartlidge and don't know how to put them back. have printer connected to computer...
Try to fix the 1200 error first. The error indicates that the cartridge carrier has stalled. Please refer to this article to fix the problem: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One. Once your cartridge carrier is functioning properl, re-insert your cartridges - How to Install Ink Cartridges In Lexmark X4200 Series AIO.
You can download the Lexmark X4270 driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
For your scanning concern, especially when scanning documents, you will need the Lexmark OCR scan software to do the job. The scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for additional assistance.
Jun 14, 2011 | Lexmark X4270 All-In-One InkJet Printer
First time using, says error #1200
The 1200 error indicates that either the cartridge/s is not properly installed or snapped in the cartridge carrier, the encoder strip (transparent strip behind the cartridge carrier) is out of place or something is blocking the cartridge carrier's path. This article 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One will help you identify and resolve the issue.
May 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
Eroor 1200 is showing
May 30, 2011 | Lexmark X4270 All-In-One InkJet Printer
Error 1200 is showing
The 1200 error could be caused by a cartridge not properly inserted in the carrier, encoder strip got unseated from its position or there's something blocking the cartridge carrier path. Try to refer to this article in the Lexmark website to determine what's causing this and resolve the problem: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
May 19, 2011 | Lexmark X4270 All-In-One InkJet Printer
We are not able to send faxes,the error message is 1200. The reference number for the fax is x4270.
The 1200 error indicates the cartridge carrier has stalled. It could be caused by a cartridge that's not properly seated or the encoder strip (transparent strip behind the cartridge carrier) is out of place. Refer to this article from the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One to help you identify and resolve the problem.
If you need additional assistance, please contact Lexmark technical support. Thanks.
Nov 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
Printer keeps popping up Error 1200 on The lexmark x4270
The 1200 error code indicates that the cartridge carrier has stalled. Refer to this article 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One on how to troubleshoot this problem. If error continues after going through the steps, I would suggest you contact Lexmark technical support so they can further look into this issue. Thanks.
Nov 09, 2010 | Lexmark X4270 All-In-One InkJet Printer
Printer shows error 1200. how do I fix?
The error 1200 is caused by the cartridge carrier getting stalled. That can be due to several causes. Here's an article in the Lexmark website to guide you to identify and, hopefully, resolve the problem. Just click on this link: http://bit.ly/9QxkWP. Hope this helps. If you need more assistance, place a comment so I can get back to this. Thanks.
Apr 13, 2010 | Lexmark X4270 All-In-One InkJet Printer
119 people viewed this question
k24674
