Question about GE 46GW 948 46" Rear Projection Television
Cracked screen The screen on my GE 46GW948 model projection tv has been cracked is there anyway to replace this?
  • chrisp952 Apr 22, 2009
    The screen on my GE 46GW948 tv is cracked also.I have tried Thomson, Global and vancebaldwin like the suggestion but can find no information.
  • 513 Answers
I think that Thomson is the manufacturer or distributor for GE parts, and Global INC is one of their distributers. keep that it mind when looking for your screen. and you might be able to get it at vancebaldwin.com good luck
Posted on Mar 16, 2006
Lost manual for GE 46GW948 tv
try looking it up online,and you can download it
Oct 19, 2009 | GE 46GW 948 46" Rear Projection Television
Picture at top of screen, bottom half is black...middle of screen has horizontal red, green line which is slightly bowed upward. model # is GE 46gw948
Call a good TV Tech and tell him the Convergence Amp IC's need to be replaced. Should not cost over $325.
Jul 29, 2009 | Televison & Video
GE 46GW948 shuts off when cold then works fine
This is a classis symptom of poor solder connections that when heated connect well. If you can solder, you should be able to fix this yourself. Resolder any connections that appear to be grainy or have rings. Note: The most likely location of these poor connections are at the convergence ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. There are high voltages floating around inside these sets even when unplugged, so be careful.
Keep me posted.
Dan
Oct 27, 2008 | GE 46GW 948 46" Rear Projection Television
GE Gemstar 46" model 46GW948
can you hear the starting or a noise from the back?try unplugging then put back.sound to me that you will need a tech
most probably the trippler going bad.
Jose
Aug 09, 2008 | GE 46GW 948 46" Rear Projection Television
Ge projection tv
can you hear the tv starting on or a noise from the back
it may be the trippler or the power supply
Jun 14, 2008 | GE 46GW 948 46" Rear Projection Television
TV problem 46GW948 GE 48? Thomson Guide Plus GemStar
i hope this helps. on the tv, press menu, then channel up or down to "screen", then menu;
then channel up or down for adjust projection tv(6), then press menu;
then use the volume up and down, as well as the channel up and down until each of the 3 colors are lined up. press menu after each color i slined up to go to the next color.
hope this helps.
May 29, 2008 | Televison & Video
SET JUST CLICKS WHEN POWER BUTTON IS PUSHED
I would check the low votage regulators, horizontal output and the flyback. The relay is the first stage of the start up process so the standby voltages are suspect as are the oscilation / Hv circuits. how are your trouble shooting skills?
May 23, 2008 | GE 46GW947 46" Rear Projection Television
Tv screen is cracked
try www.tvscreenprotectors.com
they help with finding discontinued tv screens
Apr 29, 2008 | Toshiba TP55H60 55" Rear Projection...
GE 46GW948
you should just need to go from the audio o/p of the tv. to the amp. now the tv will have either fixed or variable audio out. if fixed ok, if variable, you just need to know that the volume out of the jacks in the back is directly related to the volume of the tv, so you will need to keep the tv volume up a ways. now on the amp hook up to an available input, make sure that the input you use is set to recieve an analog signal. this is very important. every amp is different you may need to read the manual on how to adjust the input from analog/digital/audo. good luck.
Jan 08, 2007 | GE 46GW947 46" Rear Projection Television
Menu going crazy on the screen!
it sound as the menu button is staked, is a easy job for a tech, but dificult one for regular people, better get a tech and let him know that you know the problem is the menu button, thas gonna help with the price off the repair...good luck
Aug 06, 2006 | GE 46GW 948 46" Rear Projection Television
Open Questions:
See all GE 46GW 948 46" Rear Projection Television Questions
GE 46GW 948 46" Rear Projection Television Logo
135 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
