Question about Frigidaire GLMV169D Microwave Oven
Unable to use touch panel
Microwave powers up but the touch panel does not work - unable to set the date and time or use the microwave
  • suemas Sep 23, 2008
    The hard reset does not fix the problem. I think the front panel is faulty - can it be changed??
  • William Miller
    William Miller May 11, 2010
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for maybe an hour.
    Then let us know if the hard reset does not fix it.
  • Frigidaire Master
  • 9,098 Answers
You probably have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
Posted on Sep 24, 2008
How do I reset the lg microwave. It's asking reset date but my touch screen
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Jan 07, 2015 | LG LMV1630ST Microwave Oven
Got switched off suddenly and all panel lights got off
The main fuse is inside the cabinet near where the power cord enters. When everything goes dead all of a sudden, 99.9% of the time it's the fuse.
Apr 05, 2014 | KitchenAid KHMS2050SSS Microwave Oven
Unable to adjust power level, the power level button on the control panel does not respond.
Try pressing and adjusting the power level before setting the cook time, or maybe before pressing start. Worked on my Panasonic
Dec 12, 2013 | Microwave Ovens
How do i remove the control panel
Hi Colin, On our microwave , unplug first, husband just removed thewhole outer casing of microwave and pushed the button through the back, he did not touch the control panel. Hope this helpskind regardsChristine
Nov 20, 2011 | Panasonic NN-H275 Microwave Oven
Kenmore Microwave Oven, Model#66568680891
you should change the touch panel and or the control module.check to make sure the power supplied is correct and all connections to the board are all secure.
Feb 24, 2010 | Microwave Ovens
Unable to set microwave clock
sometimes the clock resets after unpluging for a short period. when you restart / power up note the time it starts at generally 12:00 miday good luck gbw
Feb 07, 2010 | Sharp Microwave Ovens
My Panasonic microwave oven has started ''beeping'' the night during cold weather and also if the kitchen door is open sometimes. This morning the Micropower button is not working so am unable to use the...
Hi the touch mabrane panel will be faulty and need to be replaced. Best place to obtain one of these or a service engineer is from the manufacturer.
Hope this helps
Jan 07, 2010 | Microwave Ovens
Microwave shut off like it lost power but the receptacle does have power to it. My model is an LVM1750.
The thermal cut out switch in the cavity is bad. I was unable to locate a wiring diagram on the internet but when I took the microwave apart, I found the wiring diagram inside the microwave on the back side of the touch panel.
This unit is mounted above the stove. We were cooking on the stove and also in the microwave. I think there was enough heat to trip the TCO switch.
Nov 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Unable to get the touch bottom to work
Quite often on the compact models, the solution is to pull the control panel assembly off, remove the circuit board and clean the surfaces shown in the photo with high-grade alcohol.
That would include the back of the LCD glass and both sides of the rubber strip.
Jan 04, 2009 | Sharp R-1480 Microwave Oven
Frigidaire GLMV169D Microwave Oven Logo
55 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
