Question about Husqvarna Viking 1
Water damage pedal was imersed in 1 inch of water by a pipe break. All the lights come on but the machine will not work. what can i do?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
Take it to an authorized dealer. The Designer 1 only has one working part in the foot control, and maybe a cord retracting reel if it is an older model. With the cord reel, the part will be pretty pricey but without the reel it won't be too expensive.
The first thing that they should do is check the machine with a working foot control to see if the machine functions normally. As long as it does, things are not too serious.
Posted on Sep 29, 2008
What would cause my Kenmore sewing machine's light to turn on but the motor seem to have no power?
The wiring for the older Kenmore is simple. The light switch completes the connection to the light. If the foot pedal has failed or connection loose where the wire attaches from the foot-pedal the motor will not run.
Also if the brushes in the motor are worn or failing to contact the motor internally the motor will not run.
With light on and pedal partially depressed attempt to activate motor to determine if brush connection are faulty. If the motor reacts at all the brushes will likely need to be replaced.
No success borrow a foot pedal from a friend or sewing center to determine if the pedal control is faulty.
Hope this helps?
Oct 15, 2016 | Kenmore Sewing Machines
Viking 980 foot pedal not making contact with machine although machine has power.
It could be lint jammed into the jack the cord plugs into. Make sure the jack and plug are both clean and free of lint. It also could be a damaged cord. If a friend has a working Viking pedal try borrowing theirs to see if it works on your machine. If not, your machine might need service.
Sep 15, 2014 | Husqvarna Viking 1
Viking sew easy 350
It sounds like the computer has lost the program. What model do you have?
Jan 24, 2014 | Sewing Machines
Can serger for about 3 inches on my brother 1354d serger and then thread breaks
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
Jan 01, 2013 | Sewing Machines
Has anyone had an issue with the husqvarna 600e continuously breaking needles?
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. machine could also be out of time
Aug 29, 2012 | Husqvarna Viking 1
My juki serger mo-634de suddenly stopped working. Lights on, wheels and parts move freely, even stitching seems to work if I turn it manually, but nothing happens when I push the pedal. No sound. ...
Hi, I have the exact same machine. it sounds like the wire from the foot pedal to the machine is broken. You would still get power from the wall to the machine to light the light, but no 'gas pedal'. You could maybe get an electrian to test the connection under the foot pedal and if the wire is damaged? or maybe the part that plugs in the machine is cracked or damaged?
Good luck! Annette
Jan 08, 2012 | Sewing Machines
I've lost my manual and video need threading info
One of the most common mistakes with overlockers is that the threads must always be threaded in order. So if you sew about 1 inch and the thread breaks try unthreading the eyes of the needles rethread the looper and then rethread the eyes of thew needles. If not you will get the same result of sewing about 1 inch and it will break again.
Aug 26, 2008 | Baby Lock Ellure
Sewing Machines Logo
62 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
