Question about Xerox Phaser 8500/DN Printer
Phaser 8560n printing greenish instead of cyan
From what I've found on the internet they say to purge the print heads. How do i do that?
  • Anonymous Sep 30, 2008
    All my pictures have a greenish tinge. I don't know if it's supposed to have more cyan or not but it's just green all over!
    President:
  • 2,072 Answers
Just shut it down for about 15 minutes and turn it back on. Every long warm up the machine will **** out the old ink and refull. Some of those odd sounds is a compressor emptying the print head.
You may not get the true blue you want. That is a shortfall on that machine, I have battled getting a greenish blue tint on that product.
Have not received a good answer from engineering. Frustraiting.
Posted on Sep 10, 2008
Error code 6A00
The 6A00 is a Canon generic code for paper path jam. Somewhere in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if it is jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs Incidentally, the 6A00 error pertains to all Canon printers made in the last several years; it is not just used in one model. And it is always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow. Move back and forth several times (with the power off)
Feb 12, 2011 | Canon MP830 All-In-One Printer
I have a mp780 and there is an error 6A00
Hi there
This answers with a titch more detail.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it's always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Thanks for using fixya....
Nov 02, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Error code 6a00
Hi there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Nov 02, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6A00
Hi there
And it’s always a paper path error or purge unit.
All The Best: Pineworks
Mar 22, 2010 | Office Equipment & Supplies
Doesn't print black text despite full cartridge
It may be problem in print head or purge unit, bzt first did you try with print head cleaning under printer properties/preferences?Try few times, if not, remove ink crg., remove print head, take lint free clotch and moisture it with destilled water and put the print head on it few minits, then dry it with anoter lint free cloth.Put it back in and repeat the head cleaning and nozzle check.
If not helpfull replace print head and purge unit with absoerber
Mar 06, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
CANON MP 830 ERROR CODE 6A00
Hi there
Mar 05, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error 6A00 code showing. Tried to use printer, this code was showing on display panel. Tried turning off and resetting. checked for any paper jams...none. Checked ink cartridges and there doesn't seem to...
Hi there
Mar 01, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error message 6A00
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Feb 04, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Error 6A00 appears. Wil not print. Cannot find
I found this elsewhere and it is from a Canon technician.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma would still be under Canon warranty, get it into a shop and save yourself the hassel.
so what I would do is check for something blocking the paper path, plus turn off the printer, manually move the print head from one side to the other and back, and then turn the printer back on.
Jan 08, 2010 | Canon PIXMA MP610 InkJet Printer
Jam in output tray
This is a paper path jam. Somewhere in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. A Canon tech advised me that, almost 90% of the time, this is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crumbs, flower bud pods or the like. And yes she has found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. If it is still under Canon warranty, get it into a shop and save yourself the hassle.
Incidently, this error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use. Also, its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
The purge unit is usually a white plastic assembly (on the right side of the printer where the print head homes) that is spring loaded and rides on a rail. You can try to move it back and forth (actually forward and back) about 5 times, close everything up, and restart. Note the the purge unit is NOT the print head! Also, wear surgical or other type of waterproof glove if you don't want to be marked for life with ink.
Hope this helps.
Jul 14, 2009 | Canon Pixma MP500 All-In-One InkJet...
Xerox Phaser  8500/DN Printer Logo
229 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
