Question about HP Computers & Internet
MOUSE NOT FONTIONING PROPERLY - HP Computers & Internet
    Sergeant:
  • 320 Answers
Buy a new mouse and plug into your system. Remember that, you need to restart the system once after inserting a new mouse.
Thank you
Posted on Sep 09, 2008
Hi, how can I fix this problem as you can see from the picture that is all about the TV, nothing is fontioning, i don't have any code, try and help please.
Seems like corrupted firmware. An update will help you. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Nov 10, 2017 | Televison & Video
Wireless mouse and stick won't work
Have you tried to add a mouse pad under it. I have a capricious mouse myself that has to be on a pad to work fine. If you don't have a pad just try it on a dark surface, no glass that's the worst one...
It can also be a simple battery matter, distance is also important depending of the communication technology in use.
good luck
Nov 28, 2013 | Trust Wireless Optical Mouse Mi-4150K
The mouse and the keybord are fontioning but I cannot write the product key to reinstall office 2010 so I plan now to install Office 2007 but but the same problem remains with the mouse Can you helps
make sure the battery is good ((has full charge))also you make sure the usb device for the mouse is inserted correctly into the usb port (if applicable) or if its a lead
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable)) if this fails to fix the problem you could try it in safe mode
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x right click to update driver
if your computer came with a motherboard disk the driver could be on it
hope this helps
Aug 25, 2011 | NEC Versa DX4-75 G8PRZB CPU (136530047A)
The mouse isn't working, even though the device manager says that it's working properly.
Change battery.
Make sure USB transmitter for mouse is plugged in properly.
Locate buttons on both mouse and USB transmitter. Press on both.
Nov 12, 2010 | Microsoft Wireless Mobile Mouse 3000
My mouse does not work ?
If you are working with track ball mouse than you have to service it properly
  • First remove the back cover by twisting it and take the ball out and clean it you have to clean the mouse inside also
If you are using optical mouse than check that you are working with a mouse pad it is necessary with optical mouse
If yet not working check the connecter of the mouse with green color fix it properly
At last if it does not work it means that its optical sensor has gone so u have to buy a new one
thanks
May 25, 2010 | Computers & Internet
Cannot use the double click feature on my mouse
To modify the mouse settings, open the property sheet using Start > Control Panel > Printers and Other Hardware > Mouse and select the Buttons tab as shown below. Check boxes and sliders allow the necessary modifications to be performed.
There is even a Click Lock function that is very handy for those that have trouble holding down the mouse button while using the drag and drop function.
The button configuration and Double-click speed settings must be set properly. Then it can solve your double-click problem.
Mar 25, 2010 | Logitech MX700 Cordless Optical Mouse
Sir, usb mouse is working properly but in,
if the usb mouse is working properly then there may be a problem on the button click of the mouse or, there are viruses on your computer that modified the registry in which you wont be able to do a click on your system . try it on another computer, if it works then there may be mechanical problems on your mouse. Pm me if it works or not. Thank you .
Aug 07, 2009 | Compaq Presario Notebook
Dynex wireless mouse..DX-WLMSE..Left click does not work properly...unless you Press Really HARD...???? What's wrong???
It is the problem of the Hard ware( Mouse). The contact is not get activated on soft clicks. dismantle the mouse. clean the contact points and put the click button properly might solve the problem. if not it should be replaced.
Mar 25, 2009 | Dynex Wireless Optical Mouse
My wireless mouse is not working and im trying to download free software
hi you need to check two basic things. first that either mose is not working properly or driver of that. try to re install the mouse driver and also plug your mouse in another system to check that mouse is ok or not
Mar 02, 2009 | Logitech 9311570403 Mouse
Usb logitech mouse
Replace the 2 AA batteries in the mouse and then Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
May 19, 2008 | Dell PS2 keyboard 04N454
Computers & Internet Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
