Question about AT&T Blackberry Curve 8300 Smartphone
Curve 8300 - my phone will not ring, only vibrate
When a call or anything else comes in to my phone, it no longer rings. It will vibrate if it's on vibrate, but if it's on normal or loud, it will act as if it's on silent. No sound will come out. What is wrong?
You need to sync your phone with your computer then do a wipe of handheld. this will erase everything but since you have synced you can go and restore from the computer. make sure you back up to computer first. if this does not fix it it needs to be replaced thru warranty or insurance.
Posted on Sep 10, 2008
No ring when phone call is received
Hello. Most likely the ring has been turned off. The volume adjustment setting goes from loud to soft to vibrate only and finally to no ring and no vibrate. The volume key is on the outside of the phone on the right hand edge.
Regards, Joe PS - kindly rate my answer as helpful. thank you.
Feb 18, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
How do you turn ringer on? Mine does not ring on incoming calls.
you will need to set the phone on a profile like normal to hear the phone ringing on incoming calls.
Dec 18, 2009 | AT&T Blackberry Curve 8300 Smartphone
Phone won't call out and when somone calls in it rings once and disconnects on their end, but I hear no ringing on my end
this sounds like a problem with your carrier than the phone, so you should contact them and explain the issue.
Aug 13, 2009 | AT&T Blackberry Curve 8300 Smartphone
Speaker phone wont work
Firstly, you need to check your profile settings for the phone. You can do this from the homescreen it is the megaphone icon.
Scroll to the bottom for advanced, and then edit the active profile - From the list opt for phone and check both in and out of holster settings - Which should be ring & Vibrate for phone.
Let me know how you get on with that.
Jun 04, 2009 | RIM BlackBerry Curve 8310 Smartphone
Does not ring - only vibrates
A couple of solutions to avoid doing a full software re-install.
Check your profile settings - From home screen, Profile, Advanced, Active, Edit, Phone - Check both in and out of holster to make sure the tone is active in both. If not change the settings.
Let me know how that works - there are a couple of things to look at and suggest before a re-install.
Apr 08, 2009 | RIM Blackberry Curve 8300
No sound from Bluetooth
sound as in you can not hear the person speaker or the phone ringing on your end....if these are the problems maybe the BT headset is faulty
Mar 04, 2009 | AT&T Blackberry Curve 8300 Smartphone
When set to vibrate+tone all I get is vibrate.
I had the identical problem, and was about to replace my unit. When I popped the SIM card and battery back in, the problem was solved. Basically a hard reset. Don't know whether it made a difference, but I left it out overnight. Hope this works for you.
Dec 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
Ringing period
You may have the "auto answer" option turned on. To check, pull up the phone screen as if placing a call, push the blackberry menu button, select "options", then "general options". Make sure "Auto answer" option has "Never" selected.
May 03, 2008 | AT&T Blackberry Curve 8300 Smartphone
Blackberry 8300 curve
Turn your vibrate off. The curve vibrates before it rings, it won't vibrate and ring at the same time. So with the vibrate off, you will gain about 10-15 seconds of ring time.
Apr 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
Ring tones to silent
turn the volume all the way down....
Feb 11, 2008 | AT&T Blackberry Curve 8300 Smartphone
AT&T Blackberry Curve 8300 Smartphone Logo
126 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
