Bad convergence ic's. I think STK 392-560, but it will have to check with your model #. Can buy kits online. But may also have bad open pekoe fuses and open low value resistors which the kit will not include.
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Your TV has bad convergence amplifiers. They are large integrated
circuits that are mounted on large metal heat sinks. They have
a part number on them, but might be covered up by a bracket. The
part number should start with STK. They are replaced as pairs. You will
have to find someone with the skills necessary to replace them.
