I keep losing signal on my digital tv, it is intergrated into the tv. I have a brand new freeview ariel and coax cable.
Try updating your router's firmware. A recent update from microsoft might have caused this.
Posted on Oct 18, 2008
Hitachi tv C 29 f 300Bdifferent cable jack on the back iRig my cable to it I have a good picture no sound what can I do
Check the audio settings to your TV first. If the audio is muted, or set low, there will be no audio. If there is audio with ariel signal, and audio is absent when connecting the AV cable, check it with a new AV cable.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 05, 2014 | Televison & Video
Can you tell me how to tune in a channel when ppreparing to use a freeview box on a onyx sw 1536 ld
Unless you've got an "expensive" Freeview box that modulates its output on to the RF (Aerial) connector then you can't. Most Freeview boxes have 2 aerial connectors - 1 IN from the Aerial itself and 1 OUT to connect to the TV - BUT this is ONLY a PASS-THROUGH connection. This means that the digital Freeview signal which is decoded from the aerial signals is NOT output on the OUT connector and sent down the co-axial cable to your TV. Only the "old" ANALOGUE (not Freeview NON DIGITAL) comes down that co-ax. What you should do is connect the Freeview box to your TV with a SCART cable via the SCART connectors on both. You need to select the AV input on the TV using the remote.
Even if you do have an "expensive" box that does modulate the digital decoded programmes and output these of the RF OUT connector, you should still use a SCART cable as the picture produced will be far better
Hope this helps
Jul 06, 2010 | Televison & Video
I cannot find my tv ariel hole to plug my ariel in
It's not a TV but a monitor. You need an external tuner such as a satellite or freeview (in the UK) box to drive it
Jun 29, 2009 | LG Televison & Video
I have plenty of old TV's that have a standard cable input, but no AV input (The white and yellow plugs that modern TV's have). Do they make a converter that turns the yellow and white AV plugs into a...
these are not cross compatible an rca hook up is a base band signal basically raw data, and coax(cable line) is a frequency with a carrier best suggestion I have is to buy a vcr with a coax out put and rca input that way the vcr can pick up the video signal then remodulate it onto a channel frequency and send it to the tv
Apr 14, 2009 | Televison & Video
Cannot get a singnal on either of my freeview top sets. both are durabrand,checked with other free view users theirs is working fine
this could be your signal usually a good ariel signal booster (make sure it freeview compatable) will sort the problem
Nov 29, 2008 | Televison & Video
I have an LG 32LT75 the one with a built in PVR (DVR) I have good signal strenght through my digital ariel, however the freeview keeps freezing and locking up/blanking etc. To reslove this I have had to...
Just had our tv taken away for a firmware upgrade - seems to have solved the problem. We have relatives with same model, different batch & same problem - they are currently trying to get LG to sort. If still in guarantee, give LG a call. (Don't bother emailing for help - they replied to the email the day the tv was returned - technology not their strong point! ;-)
HTH
Aug 12, 2008 | Televison & Video
Connection problems with Philips DTR220
There is such a thing as a HD areial, but in this case it sounds like you need to point the antenna in the right direction. If your freeview is digital then there is a diredtion the areial needs to piont, and there is a front and a back to it. You need to find where the signal source is located and point the areial in that direction.
Mar 30, 2008 | Televison & Video
Problemw with digital TV signal using an arieal
I recently purchased an ilo 32 inch tv and am having problems because when I first purchased it I had it connected to a cable box now I no longer have the cable box just the cable and am unable to hook it up because the connecter does not hook up to a regular cable cord is there a special connection that hooks it up directly to the cable cord? I read in the manual something about a F-type connector where can I get one?
Mar 28, 2008 | Televison & Video
Rca d52w19byx1
You could get away with replacing it if you get a 'freeview box' and connect it to the scart socket on the back of the tv and then connect your ariel into the freeview box instead.
Nov 12, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
Electro Med Services...
