I am trying to build a btx system but I am having a problem.I have now tried three diffent boards but as soon as I plug the power in they turn on straightaway and will not work for the power switch and it just turns on nothing else happens,I have unplugged all none esential items, removed the memory, changed the cpu all the usual any ideas could it be the psu HELP geoff
Turned out to be a cpu problem
Posted on Sep 11, 2008
Can i change out the motherboard on my dell dimension 4600 and use the one from my optiplex gx 520 in place of it.
No you can't. The Optiplex system board is a BTX type, and the Dimension uses an ATX style. The BTX board was supposed to be the new standard, with the layout changed to improve cooling air flow. Unfortunately, the I/O connectors (keyboard, etc.) aren't in the same place as on ATX boards, and you can't just drop the BTX board into the same case. (This is one of the reasons the new design didn't catch on. Seems people didn't like the idea of shelling out for a new case as well as the board.)
May 28, 2011 | Dell Optiplex GX520 (XG309) Motherboard
Hi, I have a Sony KDL-46XBR9 LCD Digital Color TV. This morning my son was watching cartoons and it clicked itself off. It has sometimes done this in the past, so we did something else for a couple of...
This tv have a power supply board is the causes and the problems.Ur tv power supply board finally gave out and not supply the right voltages to the tv system anymore.That the board,where the tv power a/c cord plug into it.Tries websites like, to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Televison & Video
Dell Dimension 5100 not powering up
I had a similar problem with my dell dim 5150 and after 3 days of intense research i found the problem. you see mine would not start either and all i had was the green motherboard light on and the yellow light on the power button blinking repeatedly, until i came a cross a post that said to check the USB slots, and so i did, turns out that after a very close look i noticed that one of the pins inside the USB slot were bent upwards and making contact with the metal hense not allowing the pc to boot. i used my wifes eyebrow plucking tool to straighten out the pin and wallah the pc boots up flawlessly now. so take a really close look at those USB slots and make sure all the pins are straight and not touching anything or each other. Good luck
Apr 16, 2009 | Computers & Internet
Triping breaker as soon as it is plugged in. can anyone tell me what usually is the cause of this problem when as soon as i plug the power cable in to the outlet, it would trip the breaker? no power to the...
try pluging it in on another outlet with an extension cord must be a diffent cerciut breaker if it happens again the microwave has a short. if not its that breaker or outlet.
Mar 31, 2009 | KitchenAid KCMC155J Convection/Microwave...
Sons computer reads:to enter set up:press delete enter F12, but nothing happens when trying to press buttons. acer T180. kev
Are you pressing all three at the same time. I believe that is what they are refeing too. Just keep pressing those three buttons, as the computer starts up.
Mar 21, 2009 | Acer Aspireā„¢ T180 PC Desktop
Monitor screen stays black even though it's on
Remove the memory from your unit - power it up it should beep if full communication is still happening across your m/board. No beeps you board has died. if it beeps and your using two diffent memory modules just fitt one leave the battery out and power it up = if no display pull power swap out the memory and try again. if display occurrs you have a defective memory module - throw that failed unit away
Mar 07, 2009 | Compaq Computers & Internet
I have an Intel D945GCZ mainboard At startup I
This is a diagnostic beep code which is designed to tell you something is amiss with your system. The code patterns of short and long beeps are not fully standardized, so it depends on who manufactured the BIOS for your motherboard. Generally three long beeps indicates an issue with the base memory - the first 64K. Try putting your RAM sticks in one at a time and powering up the system. Make certain they are oriented correctly (note the notch) and firmly seated in the socket.
Mar 04, 2009 | Intel D945GCZLR LGA775 1066MHz FSB DDR2...
btx power supply ? buy one on new egg .com cheap ok
Jan 05, 2008 | Computers & Internet
Ps2 power
you will need to buy a new power board for you ps2 just google it and you can find them there like 20 buck and relplacing them is easy
Dec 25, 2007 | Sony PlayStation 2 Slimline Console
No power to 12 volt, Hard drive, or Disk drives.
Retrace your steps there may be a loose wire(s). Have you checked and rechecked your pinouts? maybe one of the wires is backwards. Hate when that happens. It could be bad out of box. Try unhooking everything then one by one rehook your components. Maybe by terrible coinsidence a part fried and is preventing the machine from booting. Make sure your CPU fan is plugged in. I am installing a new motherboard now and those are the pitfalls I keep track of.
Mar 08, 2007 | Enermax (by Coolergiant) ELT400AWT Liberty...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
